Hi Niall,
Interesting questions and suggestions.
In other words, a given image could have its MIN, AVG (i.e. MEAN), MED and MAX points shown by these 'markers' and 'drop=lines'. Perhaps even the STDEV could also be shown, by using more than one 'drop-line' for the likes of MED and AVG, for example.
Yes, of course this is an excellent idea. I've been thinking on something similar since some time ago. The only problem is that the HistogramTransformation interface is quite complex indeed, and adding this feature requires some refactoring. Not a high priority, but you can count with this being implemented in some 1.5.x.
$T +(0.1 - med($T))
I assume you apply this expression with rescaling disabled --or the pedestal would be useless. Perhaps by adding a 0.1 pedestal you're losing too much dynamic range. By adding 0.1 to all pixels you are in the risk of saturating star cores and other very bright features. If you apply the expression above to a linear image, your median will probably be much less than 0.1, and you may safely use something like:
$T - Med($T) + 0.005
If you can afford rescaling, then a pedestal isn't necessary and you can just apply:
$T - Med($T)
with rescaling enabled. Of course rescaling is a linear operation. No data are lost because PixelMath stores all intermediate results using the full range of float (double if the "Use 64-bit working images" option is selected), and rescaling is carried out at the very end of the process.
The second 'wish' involves the ability to apply LINEAR transforms to the image data. In other words, I would like to be able to 'shift' my histograms 'peaks' to the 'left' and 'right' WITHOUT having to invoke a Mid-Tones Transfer Function (MTF) - which is a NON-LINEAR translation.
The best and more accurate way to apply these transformations is using PixelMath, just as you're doing.
Rd : (($T - med(bak)) * (mean(core[0]) / mean(core[0])) * 0.975) + 0.01
Gn : (($T - med(bak)) * (mean(core[0]) / mean(core[1])) * 1.000) + 0.01
Bu : (($T - med(bak)) * (mean(core[0]) / mean(core[2])) * 1.250) + 0.01
This seems basically correct. However if you sample the galaxy well, you shouldn't need the three multiplicative constants. These constants make this technique
nonanalytic, which is contrary to its main principle
My recommendation is to include more than just the galaxy cores. If you're applying the integrated galaxy light as your reference white --which is IMO an excellent color balancing technique--, then I think you should include more stellar populations, which requires extending the galaxy probe to include spiral arms, and probably the outer halo as well. This is what has given us the best results. The fact that you are sampling just the core might explain why you need to apply an increasing factor to the blue channel.
Where 'bak' is an image created by using Dynamic Crop to 'grab' a section of the image that is 'pure' background (and then dragging a copy to the Workspace, before using CTRL-Z to reinstate the original image)
You don't need DynamicCrop / Ctrl+Z. Just define a preview comprising your region of interest, and make an image from it (by dragging its view selector, or by selecting Preview > Make Image).
You're getting into the kind of image processing PixInsight is intended for. This is the
PixInsight way, and I'm glad to know you're acquainting with it so well
