Author Topic: [SOLVED - Workaround fix only] Unable to start PixInsight on Linux system  (Read 8639 times)
Offline lazjen
That's great news.  Looking forward to the fix.
Offline AdirondackAstro
The workaround posted on here doesn't seem to work for me, I'm still getting the following error:
/opt/PixInsight/bin/PixInsight: /opt/PixInsight/bin/lib/libz.so.1: version `ZLIB_1.2.9' not found (required by /usr/lib/x86_64-linux-gnu/libpng16.so.16)
/opt/PixInsight/bin/PixInsight: /opt/PixInsight/bin/lib/libstdc++.so.6: version `CXXABI_1.3.11' not found (required by /usr/lib/x86_64-linux-gnu/libmirclient.so.9)
I have the newest version of Ubuntu, and installed the latest version of PixInsight, had this issue with old version and thought uninstalling and installing the newest release would fix the problem, but no such luck.
Edit: I found a fix for this that worked for me
cd /opt/PixInsight/bin/lib
sudo mv libz.so.1 libz.so.1.bak
sudo mv libstdc++.so.6 libstdc++.so.6.bak
« Last Edit: 2017 December 18 14:41:35 by AdirondackAstro »
Offline RickS
Thanks.  Just playing around with PI on Linux for the first time and you saved me some grief :)
Offline photonhunter1
+1 thank you! Problem solved!
