Some more fuel to the edge glow issue. See this:
In the image, the top one is a long exposure dark taken with the Bulb mode, the bottom one is a short exposure bias taken with the M mode. Both were taken with the same Pentax 645z camera. The bias has edge glow and the dark doesn't. Until I found this, my 645z images cannot be perfectly calibrated using PixInsight. After I found this, I took all exposures in Bulb mode, including flat and bias, and the calibration problem is gone.
So, if this is the same edge glow you saw, then somehow Pentax figured out a way to turn it off in Bulb mode. It could be simply ampglow, as I saw some indication that its strength changes with exposure time (when taken with different exposure times in M mode).
Wei-Hao
