There are several approaches. This is the first one:
- Put in BPP all the images for the first night.
- Select one of the lights as registration reference. You can do it by double clicking on the file name in the light list.
- Run BPP.
- Once finished, you'll see that the interface is updated with the master calibration frames.
- Clear the flat and light lists. Add the flats and lights for the second night.
- Change the output directory.
- Preserve the registration reference from the first run. This way, all the images will be aligned to the same image.
The second approach:
- Put in BPP all the bias and darks.
- To add flats and lights, add them through the "Add custom" button. You should add flats and lights of the same night in the emerging menu. Change the filter name to its original name plus the date (for instance, Blue_20161122). This way, BPP will associate these lights to the flats acquired in the same night. You should do the same for each filter and each night.
- Set the output directory and registration reference.
- Run BPP.
In both cases, you should manually integrate all the image to have the master lights. Anyway, this is always highly recommendable.
Best regards,
Vicent.
