Author Topic: CosmeticCorrection Use Defect List bug  (Read 1172 times)
Offline dougggg
« on: 2016 December 11 10:48:16 »
There is a subtle bug in the CosmeticCorrection Use Defect List option. When correcting a column or row, the implementation calculates the replacement value for a pixel to be the median value of the 24 pixels in the nearest 5x5 square excluding the pixel being corrected. When correcting a pixel in a column, the two pixels directly above and below in are included in the median calculation but they should not be since in a bad column these pixels are bad data. Similarly, when correcting a row the two pixels to the left and right are included in the median calculation. I have test data to confirm.
Re: CosmeticCorrection Use Defect List bug
« Reply #1 on: 2016 December 15 02:15:31 »
Thank you for reporting this interesting, and certainly subtle, issue. Can you upload an image for testing? It would help us fix the bug more quickly.
Offline dougggg
« Reply #2 on: 2016 December 16 13:03:21 »
I’m looking at the CosmeticCorrection code in github and I think my comment is mistaken. What I notice now is that it this is question of precedence. Hot/Cold pixels are corrected first and then the defect list is applied.
