Author Topic: MMT, BPP , Apply STF  (Read 2126 times)
Offline eganz
    • Eric Ganz Flickr
« on: 2016 December 10 08:32:18 »
Here are some simple changes that might be nice:
Multiscale median transform:
Linear mask section, the amplification should be float, instead of integer. Currently, for stretched images, it would be desirable to be able to choose numbers between 1 and 2 for example.
Batch preprocessing:
It would be nice if BPP would open up the integrated images, and apply an STF. Then one could see the results, and potentially change the integration parameters etc.
(currently this can be done by opening up a 2nd instance of PixInsight, but that seems awkward).
Also, when writing the flat master files, the program should distinguish between East and West, when constructing the name.
This module should remember its settings (like batch  subframe selector), and then it would not be necessary to ask if you want to leave. (and yes, we already can drag the instance onto the desktop to save the settings which is very useful).
Integration Module:
It would be desirable for the STF to be applied (for viewing) automatically after integration. (i.e. no need to press control A). This could save a lot of clicks.
Apply STF:
it should be possible to apply the STF permanently to the image (i.e. stretch image) in an even easier way in the main program without having to use the "apply STF" script (which I currently use).
For example, sometimes one might use the STF to touch up a stretched image by using the sliders. This is convenient, and would be more convenient if you could apply the STF from the STF box, with one click.
Certainly, one will sometimes use the histogram box, or use masked stretch etc. to carefully stretch the image, but nevertheless, I find that I often use STF either to make a quick look at an image, or to modify the other stretch results.
Actually, we've heard that there may be a new stretch tool coming based upon the STF. This would be an ideal solution as it would satisfy your philosophical criteria about the original STF tool, while also allowing sliders and quick and reproducible application of stretching using the method based on this technique.
Eric
« Last Edit: 2016 December 12 05:33:44 by eganz »
