Author Topic: Problem Cleaning Up Dark Columns  (Read 2318 times)
Offline SeattleStarGazer
« on: 2016 December 09 19:21:22 »
I have a group of O-III exposures with a dark column about 4-5 pixels wide running about 2/3 the height of the sensor. It's not completely dark, but kind of salt and pepper mixed in with dark areas. Using CosmeticCorrection, I did a defect map and have played with the cold pixel SD but the column doesn't go away it just seems to get smoother. Any suggestions?
Wayne
Offline aworonow
    • Faint Light Photography
Re: Problem Cleaning Up Dark Columns
« Reply #1 on: 2016 December 10 13:55:26 »
If the "smoothness" is the distraction, use Pixel Math to add some noise to the columns. Experiment with the standard deviation of Gaussian noise, for example.
AlexW
« Reply #2 on: 2016 December 13 21:21:21 »
Thanks! I'm not an expert in PixelMath yet, Just using it to combine NB images,  so is there a way to limit the application of the process to specific columns or column ranges?
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #3 on: 2016 December 14 08:32:53 »
Wayne,
Try using the CanonBandingCorrection script.  It is not just for Canon cameras but works on any horizontal band in your image.  You may need to play with the settings a bit to get the right effect but it works really well for what you are seeing if we are talking about your image of the Horsehead region.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
