Author Topic: Resetting things  (Read 2378 times)
Offline tgervais
Resetting things
« on: 2016 December 08 17:50:54 »
I have been messing around with various screen settings and now I am at a point that I can't get things fixed or back to how they used to be.
I would like to reset the configuration,  back to its original state when I first started PI.  I am hoping there is a simple command that I can type in or click in ,  somewhere.  It would really help if I could get back to the beginning on things.
Thanks.
Offline John_Gill
Re: Resetting things
« Reply #1 on: 2016 December 09 04:14:06 »
You can reset each individual tool (process) by clicking on the icon in the bottom right corner of the tool and also under "Edit" ---> "Global Preferences" ---> "Load Default Page Settings" will reset a bunch of other settings.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline tgervais
« Reply #2 on: 2016 December 09 08:02:32 »
Thanks for the nice reply.  It is really appreciated.  Just trying to learn PixInsight which I believe will be very good for me,  once I understand it a bit more.
What I was trying to do,, more specifically - was to move the little veritcal bars on the taskbar.  They separate the various functions and they are not where I want them.  Yes I can click on them and move them but I can't get rid of them.  That is waht I was really trying to do.   Get rid of them.
Once before - I had the opportunity to reset the whole program by clickiing something.  This was when I first started with PixInsight.  It told me everything would be set back to original if I decided to go ahead.  I did that and was happy with what it gave me.
Now  that is what I really wanted.  I CLICK something that would reset the whole program to its earliest begining.
Failing that,  I will continue to hunt down the various functions found in the task bar,  so I can either remove them  or move them to a different spot.
Thanks again..
Offline John_Gill
« Reply #3 on: 2016 December 10 05:43:15 »
On the top menu line click "View" ---> "Show control bar" or Ctrl+Alt+B will turn the "Toolbar off/on".  Other handy display settings are "View" ---> "Full Screen" or "Full Desktop"
Look up
John
