Author Topic: problem integrating manually BIAS frames  (Read 2284 times)
Offline hectorbdn
« on: 2016 December 08 10:15:32 »
Hello, I'm trying to do manual integration of BIAS frames as Warren Keller's book explains but my results are that a part of the image is empty, what I'm doing wrong?
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: problem integrating manually BIAS frames
« Reply #1 on: 2016 December 09 07:20:56 »
A couple of things.  What do your individual bias frames look like?  Is this an issue before you integrate?  If not, try unchecking the "clip lower range" setting and see what happens.
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline Greg Schwimer
« Reply #2 on: 2016 December 09 08:13:25 »
Is this a DSLR camera? If so, which one? If it is...
I've seen this before with DSLR data. First, be sure that you are capturing in RAW mode only. Under View->Explorer Windows select Format Explorer. This will open it at the left if it isn't there already. Open that tab and select DSLR_RAW. At the bottom right of that window select Edit Preferences. Make sure the "No Image Flip" option is checked. You might also want to check the Pure Raw button at the bottom, but make sure it's the right setting for your camera.
- Greg
Scottsdale, Arizona, USA
Offline hectorbdn
« Reply #3 on: 2016 December 09 09:39:16 »
thanks pals! I will give it a try and report back :D  , yes it is a Canon 550D modified and cooled, No bias frame looks like that before stacking :)
