Author Topic: TVGDenoise on Ha images  (Read 3081 times)
Offline sreilly
« on: 2016 December 03 15:29:47 »
Reading over what I can find on TVGD and it addresses RGB images and LRGB both linear and non-linear but what mode should a Ha or even luminance image use? What I'm working on is a 28 hour Ha image that has been calibrated, aligned, combined, cropped, had DBE applied, and stretched using Masked Stretch. Now that I have this non-linear master image I need to remove some noise, mostly background. Suggestions very welcomed.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline lucchett
Re: TVGDenoise on Ha images
« Reply #1 on: 2016 December 05 02:49:44 »
Steve, if it is only ha or Lum, I would choose CIELAB mode, working in non linear state, and unflag the chrominance tic.
Andrea
Offline sreilly
« Reply #2 on: 2016 December 05 05:34:15 »
Thanks Andrea,
I fooled around with it a bit and found that worked fairly well. What I did discover, and have seen of late, is that the darker areas of the images have been getting a blotchy molted look. If I run the images through another program I'm not getting this. TVGD seems to accentuate these. I typically use Masked Stretch instead of Hist to keep star sizes smaller. I'll have to see if this is the cause.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline avarakin
« Reply #3 on: 2016 December 05 21:16:10 »
I would suggest to start with muredenoise script. It requires some tweaking of parameters and works only on images right after stacking, but results are amazing.
Alex
Offline lucchett
« Reply #4 on: 2016 December 06 04:19:43 »
I found the TGV D perfect for CCD images.
It just requires the proper setting of the edge protection parameter and the use of a proper lightness mask.
check your stars to see that you don't overdue.
I prefer to defer the denoise to late stages of the processing, so mure denoise is not an option to me but I know it is  also very good.
Ciao,
Andrea
Offline jerryyyyy
    • Astrobin Images
« Reply #5 on: 2016 December 06 10:32:06 »
Alex
Am a big believer too, but can you say a bit how you tweak the settings?
PS  May want to see my post above on using this with drizzled files... having a hard time.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
