Author Topic: Ha Modified T3i – Custom White Balance  (Read 2186 times)
Offline jimwaters
« on: 2016 November 30 19:03:16 »
Up until recently I was using ImagesPlus 6.5.  Because the T3i is Ha modified I used a Custom White Balance and selected the appropriate settings in ImagesPlus.  PixInsight is new territory and I am not sure what settings I should use for a Ha modified camera.
Should I set my camera to use a Custom White Balance or just shoot with the Daylight setting?  What PixInsight process settings should I be using for a Ha modified camera if any?  What about if I use an IDAS LPS-D1 filter?
Jim
Re: Ha Modified T3i – Custom White Balance
« Reply #1 on: 2016 December 01 02:12:11 »
Other users with experience in practical topics (I am a pure lab nerd these days) hopefully will chime in to provide more useful information, but in my opinion, color balancing should always be done just after preprocessing, while still in the linear phase, using appropriate tools such as BackgroundNeutralization and ColorCalibration, along with HistogramTransformation and others. Just let the raw data be acquired without modification by the preprocessing tools. If you use the BatchPreprocessing script to calibrate and align your data (strongly recommended) this happens by design. If you use the ImageCalibration tool manually, make sure you enter 'raw cfa' (without quotes) in the input format hints parameter.
