Author Topic: Annoying glitch in PixelMath  (Read 1213 times)
Offline ppistor
« on: 2016 November 23 07:26:08 »
When I copy txt-Data like this one
(d2seg(2076,  37,2076,  96)<=1.2)|
(d2seg(2131,   1,2131,  33)<=1.2)|
(d2seg(2131,  48,2131, 241)<=1.2)|
(d2seg(1414,   1,1414, 876)<=1.2)|
(d2seg(2527, 115,2527, 441)<=1.5)|
(d2seg(2621,   1,2621, 737)<=1.1)|
(d2seg(2876,   1,2876, 737)<=1.1)
into the expression editor field of PixelMath, leave the Editor by pressing "OK" and issue the "Apply" button in the main PM menue, PM usually issues a "...<*failed*> message.
There are several ways to get PM working, e.g.
_go to Expression Edito once more, simply return to themain panel and issue "Apply";
_before leaving the Expression Editor, simply add a blank space character at the end of the text, then go to "Apply";
_before leaving the Expression Editor, issue a "Parse" command; if successful, proceed to "Apply".
Is there an issue with blank, carriage return, line end or similar characters in the components of PixelMath?
Re: Annoying glitch in PixelMath
« Reply #1 on: 2016 November 24 01:02:55 »
Not that I am aware of. If I copy the PixelMath expression you've posted directly from the forum post and paste it in the Expression Editor window, then I can reproduce the same problem you are describing. However, if I paste it on a new text document in Script Editor, then copy it from the document and paste it in Expression Editor, it works without problems. I am using Mozilla Firefox on OS X.
Web browsers, text processors, email clients and other rich-text applications tend to insert special control characters at the end of text lines. This is a very frequent issue. Use a good plain text editor, such as PixInsight's Script Editor, to write and maintain complex PixelMath expressions.
The next version of PixelMath, along with a considerable extension of its function collection, will have a redesigned tool window with the current expression editor dialog integrated in the interface. This will facilitate using complex, multiline expressions, which currently are not being managed comfortably.
On a side note, the expression you are using can be rewritten in a simpler and more efficient way:
d2seg( 2076,  37, 2076,  96 ) <= 1.2 ||
d2seg( 2131,   1, 2131,  33 ) <= 1.2 ||
d2seg( 2131,  48, 2131, 241 ) <= 1.2 ||
d2seg( 1414,   1, 1414, 876 ) <= 1.2 ||
d2seg( 2527, 115, 2527, 441 ) <= 1.5 ||
d2seg( 2621,   1, 2621, 737 ) <= 1.1 ||
d2seg( 2876,   1, 2876, 737 ) <= 1.1
Note the use of the logical OR operator (||) instead of bitwise OR (|). Since you are building a logical (binary) expression, logical operators are much faster. Note also that since relational operators have higher precedence than logical operators, you don't need to enclose them in parentheses.
