Author Topic: Crash report  (Read 5281 times)
Offline David Serrano
Crash report
« on: 2009 February 21 09:57:41 »
Esto es inútil, pero es todo lo que hay:
X Error: BadIDChoice (invalid resource ID chosen for this connection) 14
  Major opcode: 53 (X_CreatePixmap)
  Resource id:  0x293d585
X Error: BadMatch (invalid parameter attributes) 8
  Extension:    158 (RENDER)
  Minor opcode: 4 (RenderCreatePicture)
  Major opcode: 55 (X_CreateGC)
  Resource id:  0x293d587
X Error: BadGC (invalid GC parameter) 13
  Major opcode: 72 (X_PutImage)
  Major opcode: 60 (X_FreeGC)
X Error: RenderBadPicture (invalid Picture parameter) 182
  Minor opcode: 8 (RenderComposite)
  Resource id:  0x293d586
  Minor opcode: 7 (RenderFreePicture)
  Resource id:  0x293d589
  Resource id:  0x293d58a
  Resource id:  0x293d58c
  Resource id:  0x293d58f
  Resource id:  0x293d590
  Resource id:  0x293d58e
  Major opcode: 59 (X_SetClipRectangles)
  Resource id:  0x293d59b
  Resource id:  0x293d59c
  Major opcode: 56 (X_ChangeGC)
  Major opcode: 70 (X_PolyFillRectangle)
[... chorrocientas veces ...] [nótese que de vez en cuando sale un opcode 56]
  Resource id:  0x293d5ac
  Resource id:  0x293d5ad
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
  Resource id:  0x293d5ae
  Resource id:  0x293d5af
  Resource id:  0x293d5b0
  Major opcode: 65 (X_PolyLine)
X Error: BadPixmap (invalid Pixmap parameter) 4
  Major opcode: 54 (X_FreePixmap)
  Resource id:  0x293d5c0
  Resource id:  0x293d5c1
  Resource id:  0x0
  Major opcode: 73 (X_GetImage)
terminate called after throwing an instance of 'pcl::EUnixSegmentationViolation'
/usr/bin/PixInsight: line 9: 22837 Aborted                 (core dumped) $dirname/$appname $*
$ gdb /usr/lib/pixinsight/PixInsight core.22837
GNU gdb 6.8-debian
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i486-linux-gnu"...
(no debugging symbols found)
warning: Can't read pathname for load map: Input/output error.
Reading symbols from /usr/lib/pixinsight/liblcms.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/liblcms.so
Reading symbols from /usr/lib/pixinsight/libjs.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/libjs.so
Reading symbols from /usr/lib/pixinsight/libzlib.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/libzlib.so
Reading symbols from /usr/lib/pixinsight/libcfitsio.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/libcfitsio.so
Reading symbols from /usr/lib/pixinsight/liblibtiff.so...
Loaded symbols for /usr/lib/pixinsight/liblibtiff.so
Reading symbols from /usr/lib/pixinsight/libjpeg.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/libjpeg.so
[... bla bla bla ...]
Loaded symbols for /usr/lib/pixinsight/NoOperation-pxm.so
Reading symbols from /usr/lib/pixinsight/PixelMath-pxm.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/PixelMath-pxm.so
Reading symbols from /usr/lib/pixinsight/Wavelets-pxm.so...
Loaded symbols for /usr/lib/pixinsight/Wavelets-pxm.so
Reading symbols from /usr/lib/pixinsight/TIFF-pxm.so...(no debugging symbols found)...done.
Loaded symbols for /usr/lib/pixinsight/TIFF-pxm.so
Core was generated by `/usr/lib/pixinsight/PixInsight /home/hue/_MG_2000.JPG'.
Program terminated with signal 6, Aborted.
[New process 22837]
[New process 3802]
[New process 11671]
[New process 11670]
[New process 11338]
[New process 11337]
[New process 21742]
[New process 22840]
[New process 21741]
[New process 6052]
[New process 30307]
[New process 6051]
[New process 30308]
[New process 22848]
[New process 3803]
#0  0xb7a11556 in raise () from /lib/libc.so.6
(gdb) bt
#1  0xb7a12d78 in abort () from /lib/libc.so.6
#2  0x00b46c18 in __gnu_cxx::__verbose_terminate_handler () from /usr/lib/pixinsight/lib/libstdc++.so.6
#3  0x00b44b05 in ?? () from /usr/lib/pixinsight/lib/libstdc++.so.6
#4  0x00b44b42 in std::terminate () from /usr/lib/pixinsight/lib/libstdc++.so.6
#5  0x00b44c7a in __cxa_throw () from /usr/lib/pixinsight/lib/libstdc++.so.6
#6  0x089fdeff in ?? ()
#7  <signal handler called>
#8  0x00000000 in ?? ()
#9  0x08bce25b in ?? ()
#10 0x08bce560 in ?? ()
#11 0x08bbdd90 in ?? ()
#12 0x09036d3d in ?? ()
#13 0x08ba995b in ?? ()
#14 0x08bb2469 in ?? ()
#15 0x08b55dcc in ?? ()
#16 0x08b57eb2 in ?? ()
#17 0x08b59ffc in ?? ()
#18 0x088492cc in ?? ()
#19 0x08849515 in ?? ()
#20 0x08a8cb88 in ?? ()
#21 0x08a3792c in ?? ()
#22 0x08a37b56 in ?? ()
#23 0x091874a1 in ?? ()
#24 0x08a9782e in ?? ()
#25 0x08a9188c in ?? ()
#26 0x08a912cf in ?? ()
#27 0x08a91192 in ?? ()
#28 0x08a91192 in ?? ()
#29 0x08a915a4 in ?? ()
#30 0x08a912cf in ?? ()
#31 0x08a91192 in ?? ()
#32 0x08a91192 in ?? ()
#33 0x08a91192 in ?? ()
#34 0x08a91192 in ?? ()
#35 0x08a91192 in ?? ()
#36 0x08a91192 in ?? ()
#37 0x08a91192 in ?? ()
#38 0x08a91192 in ?? ()
#39 0x08a91192 in ?? ()
#40 0x08a91192 in ?? ()
#41 0x08a91192 in ?? ()
#42 0x08a91192 in ?? ()
#43 0x08a91192 in ?? ()
#44 0x08a91192 in ?? ()
#45 0x08a915a4 in ?? ()
#46 0x08a912cf in ?? ()
#47 0x08a91192 in ?? ()
#48 0x08a91192 in ?? ()
#49 0x08a915a4 in ?? ()
#50 0x08a912cf in ?? ()
#51 0x08a915a4 in ?? ()
#52 0x08a912cf in ?? ()
#53 0x08a915a4 in ?? ()
#54 0x08a912cf in ?? ()
#55 0x08a915a4 in ?? ()
#56 0x08bfc29e in ?? ()
#57 0x08bfcaa7 in ?? ()
#58 0x08a8cd85 in ?? ()
#59 0x08ddf127 in ?? ()
#60 0x086328ef in ?? ()
#61 0x08a3792c in ?? ()
#62 0x08a37b56 in ?? ()
#63 0x091874a1 in ?? ()
#64 0x0918bd84 in ?? ()
#65 0x0918bf9d in ?? ()
#66 0x091b753f in ?? ()
#67 0xb7bb5368 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#68 0xb7bb8a03 in ?? () from /usr/lib/libglib-2.0.so.0
#69 0x0a903868 in ?? ()
#70 0x00000000 in ?? ()
(gdb) quit
¿Pasos para reproducir? Bueno... la instancia de pixi estaba levantada desde hace más de 24 horas, y cuando un proceso me generaba una imagen nueva, ésta se llamaba "Image150". Así que puede ser cualquier cosa...
 David Serrano
Crash report
« Reply #1 on: 2009 February 23 03:27:08 »
Hmmm, sí, efectivamente puede ser cualquier cosa, pero no por ello deja de fastidiarme :)
La terminación se ha producido en libc, y no es una violación de acceso. Aparentemente, el problema se ha generado tras una serie (muy larga parece) de errores en la comunicación con el servidor X. "invalid resource ID" e "invalid Picture parameter" son bastante reveladores. Tiene pinta de ser Qt.
¿Ninguna idea de lo que estaba ocurriendo justo en el momento del crash?
Crash report
« Reply #2 on: 2009 February 24 09:00:21 »
Quote from: "Juan Conejero"
¿Cómo sabes que es en libc? Si lo dices por que lo último que hay son llamadas a abort() y raise(), mi interpretación es que Pixi llamó a una de ellas en algún punto. Además signal 6 es SIGABRT. Pero he de decir que yo apenas he hecho C en la vida, y mucho menos depurar esta clase de backtraces, así que esta interpretación puede ser totalmente errónea.
En ese momento estaba con un Morphological (erosion). Tras jugar un poco con algunos parámetros, le subí el número de iteraciones (de 1 a 6, o de 3 a 6 o algo así) y al aplicar fue cuando se rompió. No recuerdo si arrastré el triangulito azul o si pinché en el cuadradito.
Entiendo que no quieras distribuir versiones de Pixi con información de depuración metida en los objetos (gcc -g), pero si quieres, para otras ocasiones, te puedo enviar el core resultante para que lo analices por tu cuenta, si es que guardas copias con -g en tu máquina (y si es que el core es mínimamente manejable!).
 David Serrano
Crash report
« Reply #3 on: 2009 February 24 10:57:47 »
No, realmente el problema no está en libc, ni mucho menos. Pero es libc quien se ha encargado de "salir" de una forma mínimamente ordenada, es decir mediante una llamada a abort(). Esto indica que no estamos frente a un crash típico ocasionado por un acceso incontrolado a la memoria, sino ante algo mucho menos perverso. Me inclino a pensar que alguna rutina interna de Qt se ha descontrolado, sobre todo por la ristra de errores de comunicación con X. En cualquier caso, estoy casi seguro de que eso no se ha originado en mi código (lo cual es consuelo de tontos, ya lo sé :) ).
