I would like to re-visit and re-post the subject that has been asked more than a year ago by another User but generated zero replies, maybe someone can help and answer these questions or provide directions to tutorials/processing examples how to properly handle mosaic panels and what is the sequence of processing steps?
Original post:
As you might have read in another threat here, I'm working on a mosaic of 6 full frame images. (Carina Nebula to Running Chicken)
I succeeded in aligning and merging the panels using the MosaicByCoordinates script. (thx for the tip on that one!)
Now I want to do a proper mosaic, but run into the challenge that the intensity AND color balance seems quite different between panels.
I've tried using the dnaLinearFit 0.1 found through the tutorial on trapped photons (
http://trappedphotons.com/blog/?p=994)
but I get very 'strange' results and some clipped pixels. Strange meaning very strong color differences over the panels, with mainly a big difference between carina and the other panels.
So I thought I'd better start over and make sure the panels are proper before aligning them. However, I wonder what the best approach is here;
- Should I apply individual BackgroundNeutralizations or could I use a background preview on 1 panel to apply it on other panels?
- Should I apply Colorcalibration already? And then same question as before; each panel individually or use the preview of 1 panel on the other panels?
- the Carina panel has 260 minutes integration time, Running Chicken 160 and the other panels 90 minutes. Which panel is best to use as reference for any form of LinearFit? The brightest one or another?
I've not come to the stage of removing bright stars at the edges etc. , but have read up on all those tips. Just want to do this step by step, Step 1 being the alignment and ability to stitch the frames together
Your help is very much appreciated!
