Author Topic: Startup memory violation  (Read 1298 times)
Offline brew
« on: 2016 November 13 15:33:27 »
I have been running PI fine for some time. Today I went to start it up, and got an error popup
     Memory access violation address 0x0000000.
PI never comes up after this.
I have tried running as administrator, running the second copy of PI, running with Control key pressed. No luck.
I rebooted the machine, no luck.
I uninstalled/reinstalled (1.8.4.1195), no luck.
I am running Win10 64 bit on a lenovo laptop. No other problems have been occurring. I have not updated any software, etc; I have Windows update turned off (for about 2 months now) so it doesn't keep messing things up.
What else can I do to get this working again?
Offline brew
Re: Startup memory violation
« Reply #1 on: 2016 November 13 16:14:30 »
I should also note that when performing the Control key start the memory violation occurs before the screen warning about clearing the settings.
Offline brew
« Reply #2 on: 2016 November 20 19:32:13 »
Finally got it fixed.
In the folder AppData\Roaming\Pleiades is a file PixInsight.ini. It looked OK, although I don't know what it should have in it. Anyway, renamed the file and Pixinsight was able to start (and immediately made a new version of the file).
Offline multispeed
« Reply #3 on: 2016 December 29 14:14:34 »
 :D
thanks brew!!
as dicribed here
http://pixinsight.com/forum/index.php?topic=9425.msg63030#msg63030
worked also for me!  finally i can use PI now :)
hope it helps other too
cs
Werner
EQ8, SW 12" f/5 PDS, G2-8300, 36mm Baader LRGB Ha OIII SII, USB Focus Heavy
EQ5 Skyscan, SW 8" f/5 PDS, 1000Da, 600Da,
Sw 6" f/5
