Author Topic: Stretching PNs with very high dynamic range  (Read 2880 times)
Offline astrovienna
« on: 2016 November 07 13:42:03 »
Could anyone walk through how to process PN data like this:
https://dl.dropboxusercontent.com/u/58468743/M57HaOIII.zip
to get both the core and the halo?  I can't seem to process this without an abrupt, ugly jump between core and halo.  I know I could take exposures of shorter duration for the core (and use one of the HDR tools to merge them), but that seems unnecessary here, since the core isn't blown out and the halo is nicely visible with some stretching.
Kevin
Offline sreilly
Re: Stretching PNs with very high dynamic range
« Reply #1 on: 2016 November 07 13:53:05 »
Try using Masked Stretch at 0.125 w/o a preview and then HDRW using as set in the screen capture but first with three (3) layers and then at five (5) as below:
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #2 on: 2016 November 08 04:18:36 »
Here it is. Two notes:
- The color image is created with ChannelCombination. H-alpha goes to R, OIII to G and B.
- "Lightness_mask" is the L component extracted from the color image after the second histogram transformation.
V.
Offline astrovienna
« Reply #3 on: 2016 November 12 09:34:31 »
Thanks, Vincent and Steve.  That was really helpful.  Both techniques seemed to work well.  In the end I followed Vincent's strategy and used AutoHisto, a tool I've never used before, instead of MaskedStretch, then applied HDRMulti.  Final results are here, one for the core only and one with the halo as well:
http://www.pbase.com/skybox/image/164511421
http://www.pbase.com/skybox/image/164511382
Kevin
