Author Topic: DrizzleIntegration no longer working well?  (Read 3019 times)
Offline kayronjm
    • Light Vortex Astronomy
« on: 2016 October 29 08:34:02 »
Hi all, last night I captured 30 Luminance frames (each 10 minutes long) of a mosaic panel around the Heart Nebula. On close inspection, all frames had perfectly round stars. The latter 13 or so were captured after a Meridian Flip, but all was looking good. I followed my usual pre-processing procedure up until DrizzleIntegration. This involves:
1. ImageCalibration
2. CosmeticCorrection
3. SubframeSelector (for custom weightings)
4. StarAlignment
5. ImageIntegration
6. DrizzleIntegration
The result that came up showed badly misaligned stars stacked together, as if the tracking/guiding wasn't good. However, all individual frames show perfect stars across the board. Moreover, the result from ImageIntegration looks perfect (albeit pixelated, as expected). This is the comparison:
Left = DrizzleIntegration
Right = ImageIntegration
For DrizzleIntegration, I used the following settings:
- Scale: 2
- Drop shrink: 0.90
- Kernel function: Square
- Enable pixel rejection
- Enable image weighting
- Enable surface splines
I tried other "Kernel functions" but to no avail. This is the first time I have ever encountered any problems using DrizzleIntegration and coincidentally it has happened after the recent update to it. Is there something wrong or am I missing something? Thank you! :)
[EDIT]: I have tried DrizzleIntegration on the first 17 frames and it looks perfect. These were captured before the Meridian Flip. I also tried DrizzleIntegration on the last 13 frames and it also looks perfect. These were captured after the Meridian Flip. The issue lies when I try to combine all the frames together - those before and those after the Meridian Flip. StarAlignment was indeed used prior to stacking, and the latter 13 frames now have the correct orientation with regards to the first 17 frames.
« Last Edit: 2016 October 29 08:51:11 by kayronjm »
- Avalon M-Uno
- Takahashi FSQ-85ED, Altair Astro 8" RC with Astro-Physics CCDT67 Telecompressor
- QSI 660wsg-8, Starlight Xpress Lodestar X2
- Astrodon E-Series Gen2 LRGB 1.25", Astrodon HA, OIII & SII 3nm 1.25"
Offline kayronjm
Re: DrizzleIntegration no longer working well?
« Reply #1 on: 2016 October 29 09:21:37 »
I would like to add to this thread that I have just uninstalled PixInsight completely, reinstalled it and updated everything EXCEPT DrizzleIntegration (yesterday's update). It's now working perfectly. Something's up in the new version! A bug introduced with the update, perhaps?
« Last Edit: 2016 October 29 11:57:24 by kayronjm »
- Avalon M-Uno
« Reply #2 on: 2016 October 31 12:18:29 »
Bug confirmed. The new version of DrizzleIntegration does not support meridian flips (rotations by 180 degrees). I am working to fix this problem ASAP. I'll release a new version with this bug fixed tomorrow. Sorry for the inconvenience.
Offline kayronjm
« Reply #3 on: 2016 October 31 16:54:03 »
Muchas gracias Juan! Un placer saber que esta todo confirmado. I will update to the version that comes next then! :)
- Avalon M-Uno
« Reply #4 on: 2016 November 02 09:57:44 »
Hi Kayron,
This bug is now fixed. I have just released an update for all supported platforms. Thank you for your patience.
