Author Topic: Master darks for preprocessing script - bias-subtracted or not?  (Read 2227 times)
Offline johnw3d
    • Flickr Astrophoto set
There doesn't seem to be any indication whether the master dark you supply to the pre-processing script should be bias-subtracted or not.  A scan of the script source suggests it assumes it is *not*, is that correct?
I do note that integrating master-bias-subtracted dark subs produces a slightly different result to subtracting a master-bias from a similarly integrated master dark from non-bias-subtracted dark subs, at least with my camera - which one is correct?
Similarly for the cosmetic-correction tool driven by a master-dark, should that be bias-subtracted or not?
Thanks for any advice,
John.
Tak FSQ-106EDX refractor, Optec focuser, 10Micron GM1000HPS mount, QHY9M + 2" filter wheel, Alnitak FlipFlat, Baader LRGB & Astrodon 3nm narrowband filters; Per's ModelMaker, SGP, PixInsight, LRCS, Photoshop
Re: Master darks for preprocessing script - bias-subtracted or not?
« Reply #1 on: 2016 October 12 16:19:50 »
Hi John,
See notes in this video
Not sure if there is any difference in which one to use...
Saludos, Alejandro
