Author Topic: stretch and target background  (Read 2309 times)
Offline ChoJin
« on: 2016 October 09 11:42:16 »
It's a simple question I suppose:
I want to stretch my image both with a HistogramTransform and a MaskedStretch and combine the results with a starmask.
if I use STF to generate my HT settings, should I use the same target background I used with STF for my MaskedStretch or should I still use a ReadOut mode to choose the target background in MaskedStretch as often said in tutorials?
I ask because although I choose a target background = 0.15 with STF, my typical background after HT is bellow 0.08 (which is normal I suppose, STF's target background is applying to the whole image, and faint stuff are probably raising the statistics).
In MaskedStretch, should I therefore still use 0.15 as a target background, (same than STF's value) or should I go with 0.08 from what I really observe with the ReadOut mode after my HT stretch? Which one should match better or make more sense overall?
Offline lucchett
Re: stretch and target background
« Reply #1 on: 2016 October 09 15:22:27 »
I think you should go for 0.15 in the target value  and give a preview of the background as a starting point for the background.
also set the upper limit after reading the average value in the preview.
sometimes I get better results getting the whole image as background reference, and this is strange in my opinion.
Andrea
Offline ChoJin
« Reply #2 on: 2016 October 10 14:24:10 »
Thanks, I'll give it a try
