Author Topic: Constant crashes and can't apply updates. Frustrated.  (Read 7107 times)
Offline mistuk
Re: Constant crashes and can't apply updates. Frustrated.
« Reply #15 on: 2016 October 12 03:12:50 »
Juan - is it worth me doing the same steps as mentioned in this thread (see my post on a similar issue)?
Kevin
Offline Lightpath
« Reply #16 on: 2016 October 12 12:12:19 »
Here are the results of the test you asked me to do:
cube:MacOS mearhard$ ./PixInsight &
[1] 24195
PixInsight Core 01.08.04.1195 Ripley (x64)
Copyright (c) 2003-2015 Pleiades Astrophoto
PixInsight 01.08.04.1195 - Critical Signal Backtrace
Signal : 11
Module : 0   PixInsight                          0x00000001035dc246 curl_slist_free_all + 1710659
34: 1   libsystem_platform.dylib            0x00007fff8fdc35aa _sigtramp + 26
33: 2   ???                                 0x00007f8bbff33170 0x0 + 140238197567856
32: 3   AppKit                              0x00007fff8ea16557 -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inGraphicsContext:CGContext:topView:shouldChangeFontReferenceColor:] + 1082(+1082)
31: 4   AppKit                              0x00007fff8eb4754e -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inContext:topView:] + 117(+117)
30: 5   AppKit                              0x00007fff8eb47455 -[NSView _drawRectBasedDisplayRectIgnoringOpacity:inContext:] + 199
29: 6   AppKit                              0x00007fff8eb4713b -[NSView displayRectIgnoringOpacity:inContext:] + 516
28: 7   AppKit                              0x00007fff8ebc097d __46-[NSView cacheDisplayInRect:toBitmapImageRep:]_block_invoke + 359
27: 8   AppKit                              0x00007fff8ebc073b __36-[NSBitmapImageRep _captureDrawing:]_block_invoke + 487
26: 9   AppKit                              0x00007fff8e92ba50 -[NSBitmapImageRep _performBlockUsingBacking:] + 35
25: 10  AppKit                              0x00007fff8ebc04bf -[NSBitmapImageRep _captureDrawing:] + 196
24: 11  AppKit                              0x00007fff8ebc03eb -[NSView cacheDisplayInRect:toBitmapImageRep:] + 185
23: 12  AppKit                              0x00007fff8ef2e020 -[NSStatusItem _updateReplicant:] + 787
22: 13  AppKit                              0x00007fff8ebb44fe __33-[NSStatusItem _updateReplicants]_block_invoke + 180
21: 14  AppKit                              0x00007fff8ebb43ef -[NSSystemStatusBar _withAdjustmentDeferred:] + 30
20: 15  AppKit                              0x00007fff8ebb43a3 -[NSStatusItem _updateReplicants] + 128
19: 16  AppKit                              0x00007fff8ef2ef72 -[NSStatusItem _updateReplicantsUnlessMenuIsTracking:] + 238
18: 17  Foundation                          0x00007fff86a72347 __NSFireDelayedPerform + 333
17: 18  CoreFoundation                      0x00007fff8dfe93e4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
16: 19  CoreFoundation                      0x00007fff8dfe8f1f __CFRunLoopDoTimer + 1151
15: 20  CoreFoundation                      0x00007fff8e05a5aa __CFRunLoopDoTimers + 298
14: 21  CoreFoundation                      0x00007fff8dfa46a5 __CFRunLoopRun + 1525
13: 22  CoreFoundation                      0x00007fff8dfa3e75 CFRunLoopRunSpecific + 309
12: 23  HIToolbox                           0x00007fff8bfb4a0d RunCurrentEventLoopInMode + 226
11: 24  HIToolbox                           0x00007fff8bfb4685 ReceiveNextEventCommon + 173
10: 25  HIToolbox                           0x00007fff8bfb45bc _BlockUntilNextEventMatchingListInModeWithFilter + 65
9: 26  AppKit                              0x00007fff8e8b524e _DPSNextEvent + 1434
8: 27  AppKit                              0x00007fff8e8b489b -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
7: 28  AppKit                              0x00007fff8e8a899c -[NSApplication run] + 553
6: 29  libqcocoa.dylib                     0x000000010a4b57ba qt_plugin_instance + 106266
5: 30  QtCore                              0x00000001074ce37c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE + 412
4: 31  QtCore                              0x00000001074d11ca _ZN16QCoreApplication4execEv + 346
3: 32  PixInsight                          0x0000000102644383 start + 1350003
2: 33  PixInsight                          0x00000001024faa44 start + 52
1: 34  ???                                 0x0000000000000001 0x0 + 1
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
Offline Lightpath
« Reply #17 on: 2016 October 12 12:29:43 »
"To solve a nontrivial problem, I need to understand it first. "
You do.  Thus it would have been much more helpful and less stressful to both of us if you had said:
"Ok, I understand you're frustrated, let's see if we can't get you sorted out.  Please execute these commands, copy the output, and paste them here.  Also, please give me the output of these crash logs."  Hell, that could even have been a copy/paste of a bunch of troubleshooting steps, and I've had happily provided it.
I'm a very technical guy.  I'm a UNIX admin, and I code as well.  I also regularly deal with frustrated customers when my tools don't work so I understand, better than most, your frustration.  I also understand that I often need my customer's help to figure out what's going wrong, and that sometimes it's not actually my fault.  That is part of this life we have chosen.
Offline Lightpath
« Reply #18 on: 2016 October 12 12:55:53 »
I have tried disabling Norton Antivirus, and quitting all software, as well as killing any other processes that were obviously not part of the OS, and had different results...
The output of running the application from the OS:
/Applications/PixInsight/PixInsight.app/Contents/MacOS
[1] 25004
2016-10-12 12:53:15.679 PixInsight[25004:507] -[__NSMallocBlock__ item]: unrecognized selector sent to instance 0x7feeb70f1780
2016-10-12 12:53:15.680 PixInsight[25004:507] -[__NSMallocBlock__ item]: unrecognized selector sent to instance 0x7feeb70f1780
2016-10-12 12:53:15.682 PixInsight[25004:507] (
   0   CoreFoundation                      0x00007fff8e08225c __exceptionPreprocess + 172
   1   libobjc.A.dylib                     0x00007fff90d6ee75 objc_exception_throw + 43
   2   CoreFoundation                      0x00007fff8e08512d -[NSObject(NSObject) doesNotRecognizeSelector:] + 205
   3   CoreFoundation                      0x00007fff8dfe0272 ___forwarding___ + 1010
   4   CoreFoundation                      0x00007fff8dfdfdf8 _CF_forwarding_prep_0 + 120
   5   libqcocoa.dylib                     0x000000010a3a285a _ZN20QCocoaSystemTrayIcon11showMessageERK7QStringS2_RK5QIconN23QPlatformSystemTrayIcon11MessageIconEi + 7818
   6   AppKit                              0x00007fff8ea16557 -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inGraphicsContext:CGContext:topView:shouldChangeFontReferenceColor:] + 1082
   7   AppKit                              0x00007fff8eb4754e -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inContext:topView:] + 117
   8   AppKit                              0x00007fff8eb47455 -[NSView _drawRectBasedDisplayRectIgnoringOpacity:inContext:] + 199
   9   AppKit                              0x00007fff8eb4713b -[NSView displayRectIgnoringOpacity:inContext:] + 516
   10  AppKit                              0x00007fff8ebc097d __46-[NSView cacheDisplayInRect:toBitmapImageRep:]_block_invoke + 359
   11  AppKit                              0x00007fff8ebc073b __36-[NSBitmapImageRep _captureDrawing:]_block_invoke + 487
   12  AppKit                              0x00007fff8e92ba50 -[NSBitmapImageRep _performBlockUsingBacking:] + 35
   13  AppKit                              0x00007fff8ebc04bf -[NSBitmapImageRep _captureDrawing:] + 196
   14  AppKit                              0x00007fff8ebc03eb -[NSView cacheDisplayInRect:toBitmapImageRep:] + 185
   15  AppKit                              0x00007fff8ef2e020 -[NSStatusItem _updateReplicant:] + 787
   16  AppKit                              0x00007fff8ebb44fe __33-[NSStatusItem _updateReplicants]_block_invoke + 180
   17  AppKit                              0x00007fff8ebb43ef -[NSSystemStatusBar _withAdjustmentDeferred:] + 30
   18  AppKit                              0x00007fff8ebb43a3 -[NSStatusItem _updateReplicants] + 128
   19  AppKit                              0x00007fff8ef2ef72 -[NSStatusItem _updateReplicantsUnlessMenuIsTracking:] + 238
   20  Foundation                          0x00007fff86a72347 __NSFireDelayedPerform + 333
   21  CoreFoundation                      0x00007fff8dfe93e4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
   22  CoreFoundation                      0x00007fff8dfe8f1f __CFRunLoopDoTimer + 1151
   23  CoreFoundation                      0x00007fff8e05a5aa __CFRunLoopDoTimers + 298
   24  CoreFoundation                      0x00007fff8dfa46a5 __CFRunLoopRun + 1525
   25  CoreFoundation                      0x00007fff8dfa3e75 CFRunLoopRunSpecific + 309
   26  HIToolbox                           0x00007fff8bfb4a0d RunCurrentEventLoopInMode + 226
   27  HIToolbox                           0x00007fff8bfb4685 ReceiveNextEventCommon + 173
   28  HIToolbox                           0x00007fff8bfb45bc _BlockUntilNextEventMatchingListInModeWithFilter + 65
   29  AppKit                              0x00007fff8e8b524e _DPSNextEvent + 1434
   30  AppKit                              0x00007fff8e8b489b -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
   31  AppKit                              0x00007fff8e8a899c -[NSApplication run] + 553
   32  libqcocoa.dylib                     0x000000010a3787ba qt_plugin_instance + 106266
   33  QtCore                              0x00000001073a237c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE + 412
   34  QtCore                              0x00000001073a51ca _ZN16QCoreApplication4execEv + 346
   35  PixInsight                          0x0000000102524383 start + 1350003
   36  PixInsight                          0x00000001023daa44 start + 52
   37  ???                                 0x0000000000000001 0x0 + 1
* Update process completed.
It looks like it completed, HOWEVER it did not actually complete the update process:  The update process failed with this message.  This is likely a permission problem of some sort:
[2016-10-12 19:53:44] Begin updater1
[2016-10-12 19:53:44] *******************************************************************************
[2016-10-12 19:53:44] This is PixInsight Updater stage one program version 01.00.11
[2016-10-12 19:53:44] Core application PID         : 25004
[2016-10-12 19:53:44] Target application directory : /Applications/PixInsight
[2016-10-12 19:53:44] Source update directory      : /tmp/PixInsight64-update/contents
[2016-10-12 19:53:44] Waiting for the PixInsight Core application to terminate...
[2016-10-12 19:53:44] PixInsight Core application terminated.
[2016-10-12 19:53:44] Waiting for things to stabilize...
[2016-10-12 19:53:46] Begin update process.
[2016-10-12 19:53:46] Source updates database loaded: /tmp/PixInsight64-update/contents/updates.xri
[2016-10-12 19:53:46] File removed: /tmp/PixInsight64-update/contents/updates.xri
[2016-10-12 19:53:46] Begin file removal process.
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/change-log.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/copyright-info.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/FrameMatrix.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/Global.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/MainModel.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/MainViewController.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/MureDenoise.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/MureEstimator.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/NR3SVD.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise/product-info.txt
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/src/scripts/mschuster/MureDenoise
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/change-log.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/copyright-info.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/product-info.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelector.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorBitmapBox.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorContourPlot.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorEditDialog.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorEvaluator.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorImageWindow.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorMD5.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorMeasure.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorParameters.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorParametersDialog.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorPropertyPlot.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorReadWriteImage.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorSectionBar.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelectorSubframeDescription.js
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/src/scripts/mschuster/SubframeSelector
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/WCSHeader/change-log.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/WCSHeader/copyright-info.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/WCSHeader/product-info.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/mschuster/WCSHeader/WCSHeader.js
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/src/scripts/mschuster/WCSHeader
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/BatchPreprocessing-engine.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/BatchPreprocessing-global.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/BatchPreprocessing-GUI.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/BatchPreprocessing-helper.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/BatchPreprocessing.js
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/change-log.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/copyright-info.txt
[2016-10-12 19:53:46] File removed: /Applications/PixInsight/src/scripts/BatchPreprocessing/product-info.txt
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/src/scripts/BatchPreprocessing
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/doc/docs
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/doc/scripts
[2016-10-12 19:53:46] Directory removed: /Applications/PixInsight/doc/tools
[2016-10-12 19:53:46] File removed: /tmp/PixInsight64-update/contents/remove.lst
[2016-10-12 19:53:46] Begin file transfer process.
[2016-10-12 19:53:46] *** Error: Unable to create file: Permission denied: /Applications/PixInsight/bin/Blink-pxm.dylib
[2016-10-12 19:53:46] End updater1: ERROR
Offline Lightpath
« Reply #19 on: 2016 October 12 12:59:15 »
I checked permissions and changed the owner of every file in the /Applications/PixinSight directory to my user, and that got the updates installed.
Offline Lightpath
« Reply #20 on: 2016 October 12 13:04:40 »
I have had it stay up before, while following a video tutorial, only to have it eventually crash but I don't recall what step that was.  I will go through the video tutorial again, and retrace my steps.  If I complete the tutorial I'll be happy it's reasonably stable.
I will also keep my system in it's current state, re-enable Norton, and see if that causes it to lose it's mind again and trigger the double free bug, but that experiment will have to wait.
Offline Lightpath
« Reply #21 on: 2016 October 13 08:43:33 »
 I spoke too soon-  It was fine until reboot, now it segfaults on startup.  I'm going to try upgrading to Sierra and see what happens.
Offline Andrei Ioda
« Reply #22 on: 2016 October 14 08:59:02 »
I have same issue on my MacBookPro with macOS 10.12 and 1.8.4.1199:
Process:               PixInsight [3931]
Path:                  /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
Identifier:            software.pleiades.PixInsight
Version:               1.8.4.1199 (1.8.4.1199)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           PixInsight [3931]
User ID:               501
Date/Time:             2016-10-14 18:55:03.318 +0300
OS Version:            Mac OS X 10.12 (16A323)
Report Version:        12
Anonymous UUID:        D7E9AF06-5668-A4AC-6991-FAFE5014267C
Sleep/Wake UUID:       6D0674E4-5D45-41F3-8745-7BE4288816E6
Time Awake Since Boot: 28000 seconds
Time Since Wake:       5700 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGABRT)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000028
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0x28:
    __TEXT                 0000000108f60000-000000010a4a5000 [ 21.3M] r-x/rwx SM=COW  /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
Application Specific Information:
abort() called
terminating with uncaught exception of type pcl::EUnixSegmentationViolation
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib           0x00007fffcce4cdda __pthread_kill + 10
1   libsystem_pthread.dylib          0x00007fffccf37797 pthread_kill + 90
2   libsystem_c.dylib                0x00007fffccdb2440 abort + 129
3   libc++abi.dylib                  0x00007fffcb91685a abort_message + 266
4   libc++abi.dylib                  0x00007fffcb93bc4f default_terminate_handler() + 267
5   libobjc.A.dylib                  0x00007fffcc444ba3 _objc_terminate() + 124
6   libc++abi.dylib                  0x00007fffcb938d69 std::__terminate(void (*)()) + 8
7   libc++abi.dylib                  0x00007fffcb9389f2 __cxa_rethrow + 99
8   libobjc.A.dylib                  0x00007fffcc442f07 objc_exception_rethrow + 40
9   com.apple.CoreFoundation         0x00007fffb7c4c8fb CFRunLoopRunSpecific + 555
10  com.apple.HIToolbox              0x00007fffb71ecf6c RunCurrentEventLoopInMode + 240
11  com.apple.HIToolbox              0x00007fffb71ecda1 ReceiveNextEventCommon + 432
12  com.apple.HIToolbox              0x00007fffb71ecbd6 _BlockUntilNextEventMatchingListInModeWithFilter + 71
13  com.apple.AppKit                 0x00007fffb58e35f5 _DPSNextEvent + 1093
14  com.apple.AppKit                 0x00007fffb5ff38eb -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637
15  libqcocoa.dylib                  0x000000011179f750 0x11177e000 + 137040
16  org.qt-project.QtCore            0x000000010e0f937c QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 412
17  org.qt-project.QtWidgets         0x000000010d3c684a QDialog::exec() + 522
18  org.qt-project.QtWidgets         0x000000010d3edfba 0x10d1a5000 + 2396090
19  software.pleiades.PixInsight     0x00000001090b08cc 0x108f60000 + 1378508
20  software.pleiades.PixInsight     0x0000000108f6a964 start + 52
Thread 1:: pi::PixInsightWatchDog
0   libsystem_kernel.dylib           0x00007fffcce4cfde __semwait_signal + 10
1   libsystem_c.dylib                0x00007fffccdd3b92 nanosleep + 199
2   org.qt-project.QtCore            0x000000010dffd47b 0x10df0e000 + 980091
3   software.pleiades.PixInsight     0x00000001090aabab 0x108f60000 + 1354667
4   org.qt-project.QtCore            0x000000010df46053 0x10df0e000 + 229459
5   libsystem_pthread.dylib          0x00007fffccf34abb _pthread_body + 180
6   libsystem_pthread.dylib          0x00007fffccf34a07 _pthread_start + 286
7   libsystem_pthread.dylib          0x00007fffccf34231 thread_start + 13
Thread 2:: WebCore: IconDatabase
0   libsystem_kernel.dylib           0x00007fffcce4cc8a __psynch_cvwait + 10
1   libsystem_pthread.dylib          0x00007fffccf3597a _pthread_cond_wait + 712
2   org.qt-project.QtWebKit          0x000000010b6d8bdb 0x10b162000 + 5729243
3   org.qt-project.QtWebKit          0x000000010b6d89c9 0x10b162000 + 5728713
4   org.qt-project.QtWebKit          0x000000010c5bf60f 0x10b162000 + 21353999
Thread 3:: com.apple.NSEventThread
0   libsystem_kernel.dylib           0x00007fffcce4541a mach_msg_trap + 10
1   libsystem_kernel.dylib           0x00007fffcce44867 mach_msg + 55
2   com.apple.CoreFoundation         0x00007fffb7c4dba4 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation         0x00007fffb7c4d021 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation         0x00007fffb7c4c874 CFRunLoopRunSpecific + 420
5   com.apple.AppKit                 0x00007fffb5a2fe9e _NSEventThread + 205
6   libsystem_pthread.dylib          0x00007fffccf34abb _pthread_body + 180
7   libsystem_pthread.dylib          0x00007fffccf34a07 _pthread_start + 286
8   libsystem_pthread.dylib          0x00007fffccf34231 thread_start + 13
Thread 4:: QFileInfoGatherer
2   org.qt-project.QtCore            0x000000010df476bb 0x10df0e000 + 235195
3   org.qt-project.QtCore            0x000000010df47572 QWaitCondition::wait(QMutex*, unsigned long) + 162
4   org.qt-project.QtWidgets         0x000000010d4062c3 QFileInfoGatherer::run() + 163
5   org.qt-project.QtCore            0x000000010df46053 0x10df0e000 + 229459
Thread 5:: Qt bearer thread
0   libsystem_kernel.dylib           0x00007fffcce4cc12 __pselect + 10
1   libsystem_kernel.dylib           0x00007fffcce49815 pselect$1050 + 82
2   org.qt-project.QtCore            0x000000010e14a3b8 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 104
3   org.qt-project.QtCore            0x000000010e14b455 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 693
4   org.qt-project.QtCore            0x000000010e14c5ca QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 234
5   org.qt-project.QtCore            0x000000010e0f937c QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 412
6   org.qt-project.QtCore            0x000000010df42525 QThread::exec() + 117
7   org.qt-project.QtCore            0x000000010df46053 0x10df0e000 + 229459
8   libsystem_pthread.dylib          0x00007fffccf34abb _pthread_body + 180
9   libsystem_pthread.dylib          0x00007fffccf34a07 _pthread_start + 286
10  libsystem_pthread.dylib          0x00007fffccf34231 thread_start + 13
Thread 6:: JavaScriptCore::BlockFree
2   org.qt-project.QtWebKit          0x000000010c2c3858 0x10b162000 + 18225240
3   org.qt-project.QtWebKit          0x000000010c5bf60f 0x10b162000 + 21353999
4   libsystem_pthread.dylib          0x00007fffccf34abb _pthread_body + 180
5   libsystem_pthread.dylib          0x00007fffccf34a07 _pthread_start + 286
6   libsystem_pthread.dylib          0x00007fffccf34231 thread_start + 13
Thread 7:: JavaScriptCore::Marking
2   org.qt-project.QtWebKit          0x000000010c2c46f7 0x10b162000 + 18228983
3   org.qt-project.QtWebKit          0x000000010c2c4788 0x10b162000 + 18229128
Thread 8:: JavaScriptCore::Marking
Thread 9:: JavaScriptCore::Marking
Thread 10:: JavaScriptCore::Marking
Thread 11:: JavaScriptCore::Marking
Thread 12:: JavaScriptCore::Marking
Thread 13:
0   libsystem_kernel.dylib           0x00007fffcce4d4e6 __workq_kernreturn + 10
1   libsystem_pthread.dylib          0x00007fffccf347c5 _pthread_wqthread + 1426
2   libsystem_pthread.dylib          0x00007fffccf34221 start_wqthread + 13
Thread 14:
Thread 15:
Thread 16:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x00007fff56c9e3b8  rdx: 0x0000000000000000
  rdi: 0x000000000000150b  rsi: 0x0000000000000006  rbp: 0x00007fff56c9e3e0  rsp: 0x00007fff56c9e3b8
   r8: 0x00007fffccddb670   r9: 0x00007fffccd9da70  r10: 0x0000000008000000  r11: 0x0000000000000206
  r12: 0x00007fff56c9e540  r13: 0x0000000000000030  r14: 0x00007fffd5a213c0  r15: 0x0000000000000008
  rip: 0x00007fffcce4cdda  rfl: 0x0000000000000206  cr2: 0x00007fffd5a03128
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
       0x108f60000 -        0x10a4a4fff +software.pleiades.PixInsight (1.8.4.1199 - 1.8.4.1199) <CC532AE2-C8DB-36D1-B9FD-5C7B84A49BF8> /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
       0x10a5cf000 -        0x10a5d3ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <47E88CED-4D65-3579-A730-B576D3E41DFA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x10a5db000 -        0x10a5fcff7 +org.qt-project.QtSensors (5.5 - 5.5.1) <8A09B415-2FDC-342E-BF90-70DDDCF668FB> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtSensors.framework/Versions/5/QtSensors
       0x10a616000 -        0x10a650fff +org.qt-project.QtPositioning (5.5 - 5.5.1) <3EBB4E03-3121-3E4F-844F-352F937C6345> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtPositioning.framework/Versions/5/QtPositioning
       0x10a665000 -        0x10a679fff +org.qt-project.QtMultimediaWidgets (5.5 - 5.5.1) <F399AD6F-BE7A-38FA-92E6-0BF4B9878E6C> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtMultimediaWidgets.framework/Versions/5/QtMultimediaWidgets
       0x10a68c000 -        0x10a720fff +org.qt-project.QtMultimedia (5.5 - 5.5.1) <C2E19B80-450F-34B9-A0A0-82D67FB8159D> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
       0x10a765000 -        0x10a7a4fff +org.qt-project.QtOpenGL (5.5 - 5.5.1) <C790BD41-3251-33F7-8455-DCC9816377AF> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
       0x10a7c7000 -        0x10a8f5fff +org.qt-project.QtSql (5.5 - 5.5.1) <E7D6A7DA-7582-33D8-8BC0-0DF22DC6B0C4> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
       0x10a913000 -        0x10a928ff7 +org.qt-project.QtWebChannel (5.5 - 5.5.1) <F8288211-9CCE-3FB2-8CCA-DC3E28E0A05B> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebChannel.framework/Versions/5/QtWebChannel
       0x10a938000 -        0x10ac9fff7 +org.qt-project.QtQml (5.5 - 5.5.1) <A17606E1-5181-3D6E-B6E7-31B97C659883> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtQml.framework/Versions/5/QtQml
       0x10ad3b000 -        0x10b02afff +org.qt-project.QtQuick (5.5 - 5.5.1) <940DB86D-D358-36FA-A748-4B62785A695D> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtQuick.framework/Versions/5/QtQuick
       0x10b109000 -        0x10b137ff7 +org.qt-project.QtWebKitWidgets (5.5 - 5.5.1) <CE8024A1-9D49-3DAA-9965-AFE478BD986E> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebKitWidgets.framework/Versions/5/QtWebKitWidgets
       0x10b162000 -        0x10cc0aff7 +org.qt-project.QtWebKit (5.5 - 5.5.1) <3E83E47D-3FC5-3200-8280-9BEC3BBCAC10> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebKit.framework/Versions/5/QtWebKit
       0x10cecc000 -        0x10cf01fff +org.qt-project.QtPrintSupport (5.5 - 5.5.1) <A33CF640-122E-3B51-84AB-45EBCA3C9297> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
       0x10cf25000 -        0x10cf62fff +org.qt-project.QtSvg (5.5 - 5.5.1) <658EA0F0-02A7-39C2-94CA-8FA8B0AD0F09> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtSvg.framework/Versions/5/QtSvg
       0x10cf80000 -        0x10cfb6fff +org.qt-project.QtXml (5.5 - 5.5.1) <124C1B9A-7C4B-3F46-ADDB-E10DB18662AE> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
       0x10cfc9000 -        0x10cfdefff +libzlib-pxi.dylib (0) <D95DC3E3-6A16-34C3-885C-E128AC3A8165> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/libzlib-pxi.dylib
       0x10cfe4000 -        0x10d035fff +liblcms-pxi.dylib (0) <A7647004-C58A-3E37-AA76-A3556D3ACA3C> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/liblcms-pxi.dylib
       0x10d11a000 -        0x10d1571c7  dyld (421.1) <A525EAEA-AF86-30C2-B360-3D093B4F0828> /usr/lib/dyld
       0x10d1a5000 -        0x10d6befff +org.qt-project.QtWidgets (5.5 - 5.5.1) <1558586A-5215-3343-A2CF-BCF1B4098587> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
       0x10d816000 -        0x10dcc5ff7 +org.qt-project.QtGui (5.5 - 5.5.1) <8C3698EB-9B9C-34C2-8E20-AAD93DEA6898> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
       0x10ddae000 -        0x10dec8ff7 +org.qt-project.QtNetwork (5.5 - 5.5.1) <3A8DD18E-C31A-38C6-A18A-41CEF1D83F66> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
       0x10df0e000 -        0x10e426fff +org.qt-project.QtCore (5.5 - 5.5.1) <75CD0FFA-6944-3050-990D-E4804B8CBCC5> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
       0x10e4c1000 -        0x10e8cdfff +libmozjs-24.dylib (1) <E33E54D2-0AB5-3A18-BA0F-B816C8FEEBFF> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/libmozjs-24.dylib
       0x10fe71000 -        0x10fe75fff  libFontRegistryUI.dylib (196) <8531768D-4B74-3CD6-992D-2FAC8E89F71B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x11177e000 -        0x111826ff7 +libqcocoa.dylib (0) <5C6AF418-32D6-3ED8-A5EE-8A414EFFCFA1> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/platforms/libqcocoa.dylib
       0x111863000 -        0x1118caff7 +org.qt-project.QtDBus (5.5 - 5.5.1) <D11BDE0E-60CB-324F-B3E7-C0A6FD4716DC> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus
       0x111df9000 -        0x111e03ff7 +libqdds.dylib (0) <292BADDC-A3F6-3C79-A11A-509D2B0F5627> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqdds.dylib
       0x111e0a000 -        0x111e11ff7 +libqgif.dylib (0) <ADB8B060-8C16-3C06-90ED-98CC9E05AB84> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqgif.dylib
       0x111e17000 -        0x111e1dff7 +libqico.dylib (0) <A9C55959-63EB-386D-869C-D6360A6CE50C> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqico.dylib
       0x115d29000 -        0x115d31fff +libqicns.dylib (0) <1A661FBF-3725-3B05-917B-CE97CA6432DA> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqicns.dylib
       0x115d38000 -        0x115dcaff7 +libqjp2.dylib (0) <344880E5-4EA4-320B-93AE-FF35486C9153> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqjp2.dylib
       0x115ddb000 -        0x115e1bfff +libqjpeg.dylib (0) <5585F3D2-323B-3DCA-B8BC-EDE8C880E62E> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqjpeg.dylib
       0x115e24000 -        0x115e76ff7 +libqmng.dylib (0) <78E7AA61-5186-317A-87BB-4A6BC0C9BFC3> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqmng.dylib
       0x115e80000 -        0x115e85ff7 +libqsvg.dylib (0) <496C9D10-EE6D-31BA-BBD0-3BEC280C95FB> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqsvg.dylib
       0x115e8c000 -        0x115e90ff7 +libqtga.dylib (0) <6151F965-1669-375A-9832-05AF03BD168B> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqtga.dylib
       0x115e96000 -        0x115efbff7 +libqtiff.dylib (0) <437CB4BF-A427-3538-8CFE-1B0BAFDC05CB> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqtiff.dylib
       0x115f06000 -        0x115f0aff7 +libqwbmp.dylib (0) <261FF3CA-0DD5-3AF8-B46F-15472CD907BA> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqwbmp.dylib
       0x115f11000 -        0x115f73ff7 +libqwebp.dylib (0) <27B75B60-F934-313A-A4B3-844FA822D773> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqwebp.dylib
       0x11d160000 -        0x11d164ff7 +libcocoaprintersupport.dylib (0) <B4B04E7A-4017-35B4-93F4-C290A34F1A0C> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/printsupport/libcocoaprintersupport.dylib
       0x11fa8f000 -        0x11fa8fff3 +cl_kernels (???) <DA85BCB6-F0B5-430A-8AB9-CB91A225263C> cl_kernels
       0x11ff6b000 -        0x11ff6cff3 +cl_kernels (???) <B3A9EDB8-DBD2-40C7-8CED-E57E88D6224B> cl_kernels
       0x1202ad000 -        0x1202aeff1 +cl_kernels (???) <9346E9B4-1965-41B6-BDE1-94D4C38ABCF5> cl_kernels
       0x1202d1000 -        0x120311ff7  com.apple.AppleShareClientCore (4.0.1 - 3.0) <22EECABD-631A-38C0-BBCC-20F5EC7FBC19> /System/Library/PrivateFrameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
       0x12033b000 -        0x120342fff  com.apple.URLMount.AFPPlugin (6.0.1 - 6.0.1) <71ACAC94-5D82-3840-BDD3-86C5DBFEEC2E> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
       0x120b8b000 -        0x121063fff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.18.65 - 10.1.8) <E7448943-FC24-3DD7-9864-3B5D07B00F9E> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
       0x12124d000 -        0x1212bdfff  com.apple.driver.AppleIntelHD4000GraphicsMTLDriver (10.18.65 - 10.1.8) <40FB170B-F33E-326B-9741-E15EFE731D71> /System/Library/Extensions/AppleIntelHD4000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsMTLDriver
       0x122ba2000 -        0x122bb7ff7 +libqcorewlanbearer.dylib (0) <F36526E2-8CBC-335D-A0F5-5B068B59F26B> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/bearer/libqcorewlanbearer.dylib
       0x122bc2000 -        0x122bcbff7 +libqgenericbearer.dylib (0) <985AA430-AD4E-344A-A7D1-EC4F26AA7BF7> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/bearer/libqgenericbearer.dylib
       0x12332e000 -        0x1233d3fff +Annotation-pxm.dylib (0) <818B0D12-7268-3BA3-AB75-01360A6AB144> /Applications/PixInsight/*/Annotation-pxm.dylib
       0x123500000 -        0x12359cff7 +AssistedColorCalibration-pxm.dylib (0) <C9563D4B-6DFB-3F84-A042-6B892FE1D413> /Applications/PixInsight/*/AssistedColorCalibration-pxm.dylib
       0x1235c7000 -        0x12371fff7 +BackgroundModelization-pxm.dylib (0) <40083F74-F1B8-3E8F-9ACF-A6A8E1EA37AD> /Applications/PixInsight/*/BackgroundModelization-pxm.dylib
       0x123773000 -        0x1238d3ff7 +Blink-pxm.dylib (0) <F407C12E-7648-35AF-9D1E-2825FD56BD2D> /Applications/PixInsight/*/Blink-pxm.dylib
       0x12390f000 -        0x1239f3fff +BMP-pxm.dylib (0) <91CC8EE4-A87A-3FA3-B91C-60B2D6C15EC3> /Applications/PixInsight/*/BMP-pxm.dylib
       0x123a27000 -        0x123bf9ff7 +CloneStamp-pxm.dylib (0) <4695A516-B177-3C92-B5BE-5360C7125764> /Applications/PixInsight/*/CloneStamp-pxm.dylib
       0x123c49000 -        0x123df1fff +ColorCalibration-pxm.dylib (0) <913BBC7D-72C1-3D11-8D64-32488AC4A504> /Applications/PixInsight/*/ColorCalibration-pxm.dylib
       0x123e38000 -        0x123eebff7 +ColorManagement-pxm.dylib (0) <84C3E18A-7FC4-3268-ABCA-5AAE537A1E63> /Applications/PixInsight/*/ColorManagement-pxm.dylib
       0x123f16000 -        0x124422ff7 +ColorSpaces-pxm.dylib (0) <5AD9E21D-5680-35B0-AEDF-D2417F3BC467> /Applications/PixInsight/*/ColorSpaces-pxm.dylib
       0x1244c3000 -        0x124605ff7 +Debayer-pxm.dylib (0) <1673F704-F615-3488-853A-AD487C95B9D0> /Applications/PixInsight/*/Debayer-pxm.dylib
       0x124642000 -        0x124657fff +libzlib-pxi.dylib (0) <D95DC3E3-6A16-34C3-885C-E128AC3A8165> /Applications/PixInsight/*/libzlib-pxi.dylib
       0x124fd3000 -        0x12521efff +CometAlignment-pxm.dylib (0) <FACEDE71-5CDF-3EB7-8554-4387DAB44145> /Applications/PixInsight/*/CometAlignment-pxm.dylib
       0x12526a000 -        0x12556ffff +Compatibility-pxm.dylib (0) <757BA340-1B50-344C-8703-25D17CC1F411> /Applications/PixInsight/*/Compatibility-pxm.dylib
       0x1255e5000 -        0x1257d9ff7 +CosmeticCorrection-pxm.dylib (0) <83C4B4AB-64D7-34DE-A8B8-36DC77DD072A> /Applications/PixInsight/*/CosmeticCorrection-pxm.dylib
       0x125820000 -        0x1258e4fff +Fourier-pxm.dylib (0) <D3894606-21D2-3565-A381-6A796171C0C9> /Applications/PixInsight/*/Fourier-pxm.dylib
       0x128d6c000 -        0x129091ff7 +Convolution-pxm.dylib (0) <8D9AFA06-A469-3C4E-A223-44D5C2610E8D> /Applications/PixInsight/*/Convolution-pxm.dylib
       0x12910b000 -        0x129370ff7 +Deconvolution-pxm.dylib (0) <3E2F55A9-2521-3F59-94F1-811F910D7BB6> /Applications/PixInsight/*/Deconvolution-pxm.dylib
       0x1293cd000 -        0x1294d0fff +DSLR_RAW-pxm.dylib (0) <A0508504-AE31-3E75-9B1E-7E95CA7C18B6> /Applications/PixInsight/*/DSLR_RAW-pxm.dylib
       0x129598000 -        0x129687fff +FITS-pxm.dylib (0) <2C9E794E-A4BD-3A4B-A969-3C1CD1581306> /Applications/PixInsight/*/FITS-pxm.dylib
       0x1296bb000 -        0x129838fff +libcfitsio-pxi.dylib (0) <4D6631B4-63C4-3967-9D07-AEEA0854C138> /Applications/PixInsight/*/libcfitsio-pxi.dylib
       0x12998c000 -        0x129abcfff +Flux-pxm.dylib (0) <B669A02B-7D8A-328D-A45C-88A67AA3D951> /Applications/PixInsight/*/Flux-pxm.dylib
       0x129b03000 -        0x129c5cfff +Geometry-pxm.dylib (0) <4206CBF9-9625-379E-8EA2-1683A7E91150> /Applications/PixInsight/*/Geometry-pxm.dylib
       0x129cb8000 -        0x129dfeff7 +Global-pxm.dylib (0) <258C65B0-DD67-3A82-9AE0-038265416A03> /Applications/PixInsight/*/Global-pxm.dylib
       0x129e57000 -        0x129f9bfff +GradientDomain-pxm.dylib (0) <C00878DE-386D-37E6-8BE0-6986FF26CB38> /Applications/PixInsight/*/GradientDomain-pxm.dylib
       0x129fdd000 -        0x12a0a6ff7 +GREYCstoration-pxm.dylib (0) <F622A688-B83E-3AEE-B58F-B3000F009490> /Applications/PixInsight/*/GREYCstoration-pxm.dylib
       0x12a0d3000 -        0x12a343ff7 +Image-pxm.dylib (0) <0FFC9802-6F38-3491-815E-72D49754AE85> /Applications/PixInsight/*/Image-pxm.dylib
       0x12a3ac000 -        0x12a62efff +ImageCalibration-pxm.dylib (0) <CB467FDA-5F4F-3529-B2E1-3BD9F4D84E6F> /Applications/PixInsight/*/ImageCalibration-pxm.dylib
       0x12a68d000 -        0x12a905ff7 +ImageIntegration-pxm.dylib (0) <E3CB0D07-1354-3141-89A3-410D94FD7C03> /Applications/PixInsight/*/ImageIntegration-pxm.dylib
       0x12a97c000 -        0x12ab18fff +INDIClient-pxm.dylib (0) <4CA22C17-B3B5-3ED9-9A4D-F31AE8E87A77> /Applications/PixInsight/*/INDIClient-pxm.dylib
       0x12ab6c000 -        0x12ac1eff7 +JPEG-pxm.dylib (0) <565B2BCB-523D-3CAD-9F4F-67A6C2846B1B> /Applications/PixInsight/*/JPEG-pxm.dylib
       0x12ac4a000 -        0x12ac8afff +libjpeg-pxi.dylib (0) <CD37FB2D-0723-3023-A4DB-B01421F1A7F0> /Applications/PixInsight/*/libjpeg-pxi.dylib
       0x12ac94000 -        0x12ace1ff7 +libjasper-pxi.dylib (0) <2B01990F-5A03-3371-992B-90905F36EE5F> /Applications/PixInsight/*/libjasper-pxi.dylib
       0x12cd71000 -        0x12d223ff7 +ImageRegistration-pxm.dylib (0) <0CCDF091-E580-3637-A15B-52513FB1CFCE> /Applications/PixInsight/*/ImageRegistration-pxm.dylib
       0x12d2df000 -        0x12d683ff7 +IntensityTransformations-pxm.dylib (0) <8165FC9F-4CE4-3639-905C-BEAD46E5ECA5> /Applications/PixInsight/*/IntensityTransformations-pxm.dylib
       0x12d734000 -        0x12d7e4ff7 +JPEG2000-pxm.dylib (0) <6A69F32B-E794-3F31-9402-346DD1A86AED> /Applications/PixInsight/*/JPEG2000-pxm.dylib
       0x12d80c000 -        0x12d8bffff +LocalHistogramEqualization-pxm.dylib (0) <B034E5F2-DE5D-3B0F-95FD-79BD8643DBD5> /Applications/PixInsight/*/LocalHistogramEqualization-pxm.dylib
       0x12d8eb000 -        0x12dad5ff7 +MaskGeneration-pxm.dylib (0) <3ECB791B-228A-31E5-93A0-2A0D4FC1FD70> /Applications/PixInsight/*/MaskGeneration-pxm.dylib
       0x12db26000 -        0x12dc8cfff +Morphology-pxm.dylib (0) <590B7625-5916-3B09-8CBF-B696592CB6C2> /Applications/PixInsight/*/Morphology-pxm.dylib
       0x12dcc6000 -        0x12e0d3fff +MultiscaleProcessing-pxm.dylib (0) <3AE7867B-DB89-3B55-8308-24697FE61ECF> /Applications/PixInsight/*/MultiscaleProcessing-pxm.dylib
       0x12e15f000 -        0x12e1e9fff +NoiseGeneration-pxm.dylib (0) <F7D6F1BC-61E5-3A90-A770-D73168F223D4> /Applications/PixInsight/*/NoiseGeneration-pxm.dylib
       0x12e211000 -        0x12e3a6ff7 +NoiseReduction-pxm.dylib (0) <C8768591-F9D4-3630-8557-23BD40B23283> /Applications/PixInsight/*/NoiseReduction-pxm.dylib
       0x12e3f4000 -        0x12e439fff +NoOperation-pxm.dylib (0) <DD4D28D6-9335-3A73-945A-4A8F96354A8D> /Applications/PixInsight/*/NoOperation-pxm.dylib
       0x12e44f000 -        0x12e5d5fff +Obsolete-pxm.dylib (0) <9CFC3E2A-5B1F-374F-AFA5-3993AE8B99C4> /Applications/PixInsight/*/Obsolete-pxm.dylib
       0x12e61a000 -        0x12e7bdfff +PixelMath-pxm.dylib (0) <7F94E7E3-044E-3934-9825-7CF87FC82C4E> /Applications/PixInsight/*/PixelMath-pxm.dylib
       0x12e822000 -        0x12ea63ff7 +RestorationFilters-pxm.dylib (0) <CFCB338C-9CE5-3EEE-8A12-1D2A620AC09B> /Applications/PixInsight/*/RestorationFilters-pxm.dylib
       0x12eac2000 -        0x12eb45ff7 +Sandbox-pxm.dylib (0) <20918D76-962A-30BD-8A2D-D4A58EED42EC> /Applications/PixInsight/*/Sandbox-pxm.dylib
       0x12eb68000 -        0x12ec34fff +SplitCFA-pxm.dylib (0) <58A8252D-288D-30AC-BE9C-D6E984C562B6> /Applications/PixInsight/*/SplitCFA-pxm.dylib
       0x12ec66000 -        0x12ed53ff7 +StarGenerator-pxm.dylib (0) <B5F2DF14-C2B1-3F08-957E-13330BF27CEF> /Applications/PixInsight/*/StarGenerator-pxm.dylib
       0x12ed88000 -        0x12ef07fff +TGV-pxm.dylib (0) <FC74705C-A81A-3726-8157-DE3B760E48FA> /Applications/PixInsight/*/TGV-pxm.dylib
       0x12ef4b000 -        0x12f02cfff +TIFF-pxm.dylib (0) <A033251F-6B37-3A52-961A-7C49BF8FC44E> /Applications/PixInsight/*/TIFF-pxm.dylib
       0x12f05b000 -        0x12f0c3fff +liblibtiff-pxi.dylib (0) <CCD981BA-162E-32A1-97E2-2057EC3B047A> /Applications/PixInsight/*/liblibtiff-pxi.dylib
       0x12f0d4000 -        0x12f226ff7 +XISF-pxm.dylib (0) <908DD756-D1E1-39EC-B706-27DF3C51C275> /Applications/PixInsight/*/XISF-pxm.dylib
       0x130d36000 -        0x130d52fff  com.apple.security.csparser (3.0 - 57740.1.18) <59FC4D03-99ED-3543-B26B-E466B074EAF9> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
    0x7fffb2917000 -     0x7fffb2c4ffff  com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fffb323f000 -     0x7fffb3a8bfff  com.apple.GeForceGLDriver (10.12.65 - 10.1.2) <6AF074C0-3325-3889-A3B0-7253D4383C29> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x7fffb3a8c000 -     0x7fffb435aff3  libclh.dylib (4.0.3 - 4.0.3) <035FC9AA-7ED0-35ED-8951-0184C530027C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x7fffb435b000 -     0x7fffb446bff7  com.apple.GeForceMTLDriver (10.12.65 - 10.1.2) <81626155-E747-3405-BCD7-244BAC72DC00> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
    0x7fffb446c000 -     0x7fffb462afff  com.apple.avfoundation (2.0 - 1183.3) <E6DCAB50-ECD4-3645-8A93-D14F14092DC4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fffb462b000 -     0x7fffb46ceff7  com.apple.audio.AVFAudio (1.0 - ???) <18E472FC-5AD7-33B8-8D46-49D5AC2DB13A> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fffb46cf000 -     0x7fffb4760ff7  com.apple.AVKit (1.1 - 338.5) <FE78535E-A224-3D3D-AE2C-AC5DE1BAC007> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
    0x7fffb4761000 -     0x7fffb4761fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffb4762000 -     0x7fffb4779ff3  libCGInterfaces.dylib (331.4) <2CD05A85-79AC-3C67-9ABE-00294CE1C82B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffb477a000 -     0x7fffb4dbafe3  com.apple.vImage (8.1 - ???) <6CC22156-EC5C-3DC3-8132-41376F090B08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffb4dbb000 -     0x7fffb4f82fef  libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffb4f83000 -     0x7fffb4f9afff  libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffb4f9b000 -     0x7fffb53a6fff  libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffb53a7000 -     0x7fffb53bdfff  libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffb53be000 -     0x7fffb53c4fff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffb53c5000 -     0x7fffb53d8ff7  libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffb53d9000 -     0x7fffb5526ff7  libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffb5527000 -     0x7fffb55defff  libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffb55df000 -     0x7fffb55dffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffb55e0000 -     0x7fffb5620ffb  com.apple.Accounts (113 - 113) <4A825926-C148-3EC1-9017-3B101849D8C8> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fffb5621000 -     0x7fffb589bff7  com.apple.AddressBook.framework (10.0 - 1756) <861F3080-999E-39FB-ABDF-EF068017978F> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fffb589c000 -     0x7fffb6573ff3  com.apple.AppKit (6.9 - 1504) <5524F97F-FB11-3556-8AC4-FF634C6CCCB7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffb6585000 -     0x7fffb6585fff  com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffb6586000 -     0x7fffb65f4ff7  com.apple.ApplicationServices.ATS (377 - 422) <521E41BF-D495-3233-B6BF-C0B83DD1A8C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffb668e000 -     0x7fffb67bcfff  libFontParser.dylib (194) <CDC6A0AA-E6AC-315B-AFBF-011F64548911> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffb67bd000 -     0x7fffb6807fff  libFontRegistry.dylib (196) <3B8B0E78-2B30-3F18-B7D3-BE4E96F6BAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffb6864000 -     0x7fffb6896fff  libTrueTypeScaler.dylib (194) <E8B9E8E7-1F7A-3700-895C-501C12EDD001> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffb6902000 -     0x7fffb69acff7  com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffb69ad000 -     0x7fffb69fdfff  com.apple.HIServices (1.22 - 589) <3167EF9C-F121-39EF-AAE2-7700E7128426> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffb69fe000 -     0x7fffb6a0dff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffb6a0e000 -     0x7fffb6a5bfff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffb6a5c000 -     0x7fffb6a97fff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffb6a98000 -     0x7fffb6aa3ff7  com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffb6aa4000 -     0x7fffb6cb0fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <EDDC86C8-92F3-34C6-A5C1-A176ADA724C3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffb6cb1000 -     0x7fffb6cb1fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <AA9DB0D2-3B2F-3366-B451-DD9E89038F6F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffb6e1a000 -     0x7fffb719dfff  com.apple.CFNetwork (807.0.4 - 807.0.4) <A338A213-4FFF-3317-B4DB-84735C63C507> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffb71b7000 -     0x7fffb71b7fff  com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fffb71b8000 -     0x7fffb71bbfff  com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fffb71bc000 -     0x7fffb74bffff  com.apple.HIToolbox (2.1.1 - 855) <AA4E2957-6B2D-3822-881C-0F64222F9578> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffb74c0000 -     0x7fffb74c3ff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fffb74c4000 -     0x7fffb74c9fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fffb74ca000 -     0x7fffb7561ff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffb7562000 -     0x7fffb757cfff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fffb757d000 -     0x7fffb757eff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fffb757f000 -     0x7fffb7581ff7  com.apple.securityhi (9.0 - 55006) <856F4FB9-AAF2-3FC2-BE19-E7AB494232CC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fffb7582000 -     0x7fffb7588ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffb7589000 -     0x7fffb7667ffb  com.apple.cloudkit.CloudKit (638.1 - 638.1) <C81C2824-1E30-3887-A499-43755EDF27C7> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fffb7668000 -     0x7fffb7668fff  com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fffb779b000 -     0x7fffb782bff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <0352D931-596B-3AFE-B5C6-5925CF9F870E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffb782c000 -     0x7fffb783fff3  com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffb7840000 -     0x7fffb7b3afff  com.apple.CoreData (120 - 752.2) <51AB540E-01AE-3207-8DE5-3E912FA9B5DF> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffb7b3b000 -     0x7fffb7bc7fff  com.apple.CoreDisplay (1.0 - 1) <F10E2F1A-FA51-3256-BCCE-34FF30AB1E3A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffb7bc8000 -     0x7fffb805bff7  com.apple.CoreFoundation (6.9 - 1348.1) <2A35BE4F-BA5B-3C22-BCF1-CFBBA2786081> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffb805c000 -     0x7fffb86fcff7  com.apple.CoreGraphics (2.0 - 1070) <765D6A92-48AE-3CBB-9967-61300D715F1F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffb86fd000 -     0x7fffb893cff7  com.apple.CoreImage (12.0.0 - 451) <84C71E9C-5231-342F-94B1-2BB6860E8AD3> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffb893d000 -     0x7fffb8999ff7  com.apple.corelocation (2100.3.13) <1064F400-1027-34D7-8F24-CDCB6DAF0F16> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fffb899a000 -     0x7fffb8a4aff7  com.apple.CoreMedia (1.0 - 1903.7) <5FE3B4CC-EC1A-38FE-96FA-FFD419229F3E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fffb8a4b000 -     0x7fffb8a96ff7  com.apple.CoreMediaIO (801.0 - 4922) <2813BA18-E24C-3CFB-8B34-73575DFDF0BC> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fffb8a97000 -     0x7fffb8a97fff  com.apple.CoreServices (775.8 - 775.8) <C36F7F47-D585-32F2-8A6F-7711935CDFD6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffb8a98000 -     0x7fffb8ae9ff7  com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffb8aea000 -     0x7fffb8dc5fff  com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffb8dc6000 -     0x7fffb8df9fff  com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffb8dfa000 -     0x7fffb8e02ffb  com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffb8e03000 -     0x7fffb8f6efff  com.apple.LaunchServices (775.8 - 775.8) <6E7CE1DA-27A4-3B48-A8E3-F2AA868ADD7C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffb8f6f000 -     0x7fffb901fffb  com.apple.Metadata (10.7.0 - 1075) <9EDF10CF-1755-346A-A3C9-97642C443A58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffb9020000 -     0x7fffb907ffff  com.apple.CoreServices.OSServices (775.8 - 775.8) <FCF1334F-D2D7-3C5A-A8FE-C173C5EDE586> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffb9080000 -     0x7fffb90f0fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffb90f1000 -     0x7fffb9137ff7  com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffb91c4000 -     0x7fffb930fff7  com.apple.CoreText (352.0 - 544) <064B53E8-CD5A-3D1B-81DF-498A659FC20A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffb9310000 -     0x7fffb9345fff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffb9346000 -     0x7fffb93b7ffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <F46EF4A2-C348-3F76-A1C2-B8A84C17FE2B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffb93e7000 -     0x7fffb93f2ff3  com.apple.DirectoryService.Framework (10.12 - 194) <829AFAAD-5742-332D-B84D-AF161FB57660> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fffb93f3000 -     0x7fffb94b1ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <EA175710-9775-3147-8AF9-7B20D2872723> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fffb94b2000 -     0x7fffb94b7fff  com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffb9646000 -     0x7fffb99edffb  com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffb9a19000 -     0x7fffb9a4aff3  com.apple.GSS (4.0 - 2.0) <B30A0B99-AFDE-3BF8-A04F-761A75A6A3B1> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffb9afe000 -     0x7fffb9ba1ffb  com.apple.Bluetooth (5.0.0 - 5.0.0f18) <00417775-D746-32C1-9598-CE8716DFBECD> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffb9ba2000 -     0x7fffb9c37fff  com.apple.framework.IOKit (2.0.2 - 1324.1.7) <10BDCD1E-0463-3C53-BF11-C9A0919C1588> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffb9c38000 -     0x7fffb9c3effb  com.apple.IOSurface (152 - 152) <558D4451-2D9D-3D47-B3A5-E7C18DF53F1B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffb9c3f000 -     0x7fffb9c91ff3  com.apple.ImageCaptureCore (7.0 - 7.0) <EF8DF81D-3D82-3202-BE75-E49D38EC105D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fffb9c92000 -     0x7fffb9debff7  com.apple.ImageIO.framework (3.3.0 - 1570.1) <6B0177F3-A7BE-30D7-B075-7117E2C28A5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffb9dec000 -     0x7fffb9df0fff  libGIF.dylib (1570.1) <AE06146E-C4B3-3088-B6BC-569DDFCD8D77> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffb9df1000 -     0x7fffb9ee2fff  libJP2.dylib (1570.1) <6D268C9D-309B-3098-BBCF-8A1B98DBBEE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffb9ee3000 -     0x7fffb9f06fff  libJPEG.dylib (1570.1) <7EFA7A91-06C8-329E-AA3D-CF6DB2220A5A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffb9f07000 -     0x7fffb9f2dfff  libPng.dylib (1570.1) <AF8292B6-2564-30D4-8860-6B0C9D0E1405> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffb9f2e000 -     0x7fffb9f30ff3  libRadiance.dylib (1570.1) <B0256EB7-7F87-39FD-BD35-83577F4FE7EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffb9f31000 -     0x7fffb9f8afff  libTIFF.dylib (1570.1) <F1F0B7C6-388F-35E4-87CF-816CEE8B0E00> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffba0aa000 -     0x7fffbab50ff7  com.apple.JavaScriptCore (12602 - 12602.1.50.0.5) <D701E578-C347-392D-BB90-1B144DAAAEEB> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fffbab51000 -     0x7fffbab6aff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffbab6b000 -     0x7fffbaba1fff  com.apple.LDAPFramework (2.4.28 - 194.5) <850BB4C5-2548-33A5-B00C-0600CA59EE59> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fffbade4000 -     0x7fffbadeafff  com.apple.MediaAccessibility (1.0 - 97.1.1) <EE1825C7-3B58-32F8-9F5F-B7172452BB01> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fffbae00000 -     0x7fffbb34dfff  com.apple.MediaToolbox (1.0 - 1903.7) <37363406-481C-3DDD-A61F-9E2153A3660B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fffbb34e000 -     0x7fffbb3a5ff7  com.apple.Metal (85.82 - 85.82) <CDC847A6-F1F6-3661-8981-180F2A485092> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffbbabb000 -     0x7fffbbac3fff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffbbc97000 -     0x7fffbbc9fff7  libcldcpuengine.dylib (2.8.4) <F15C17F0-3342-36BD-A28E-7AC44B87BF8C> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffbbca0000 -     0x7fffbbd86fff  unorm8_bgra.dylib (2.8.4) <387BD705-3EB5-3335-9F35-8C8E54B6A553> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fffbbd87000 -     0x7fffbbe67fe7  unorm8_rgba.dylib (2.8.4) <FB0CB303-B0CA-3A0F-AA12-2F1CC59B7E21> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
    0x7fffbbe68000 -     0x7fffbbeb6ff3  com.apple.opencl (2.8.6 - 2.8.6) <DA3164B7-EB48-3F68-A40F-CD9B433E385F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffbbeb7000 -     0x7fffbbed0ffb  com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffbbed1000 -     0x7fffbbedcff7  com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffbbedd000 -     0x7fffbbedffff  libCVMSPluginSupport.dylib (12.4.2.1) <5A7CBDC5-297E-30E0-8951-2F3DAFD0027E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffbbee0000 -     0x7fffbbee3ff7  libCoreFSCache.dylib (148) <3297ACE0-B9D8-3821-8685-2619B4234621> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffbbee4000 -     0x7fffbbee7fff  libCoreVMClient.dylib (148) <B4299590-02BA-3130-98EA-A2D3A53852E1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffbbee8000 -     0x7fffbbef0ffb  libGFXShared.dylib (12.4.2.1) <3CBE90E5-6472-3C4C-825D-7567A5652115> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffbbef1000 -     0x7fffbbefcfff  libGL.dylib (12.4.2.1) <E68C6C85-3B98-3525-9279-3296977FBF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffbbefd000 -     0x7fffbbf39ff7  libGLImage.dylib (12.4.2.1) <50C7DE05-73CB-3D21-BB93-31C384EB6199> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffbbf3a000 -     0x7fffbc0b0ffb  libGLProgrammability.dylib (12.4.2.1) <2B17044B-CDB6-38F7-BA1F-9ED1A078481A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffbc0b1000 -     0x7fffbc0f1ff3  libGLU.dylib (12.4.2.1) <D5DB68EC-751F-34D1-BCEB-2B86D560E243> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffbca59000 -     0x7fffbca67fff  com.apple.opengl (12.4.2 - 12.4.2) <06F5BF0B-BD03-361D-9D7B-626517E4F761> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffbca68000 -     0x7fffbcc0efff  GLEngine (12.4.2.1) <8FFA4B17-F02A-3D7A-ACA9-D156E4E43B4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fffbcc0f000 -     0x7fffbcc39ffb  GLRendererFloat (12.4.2.1) <82826589-22A1-312C-9C4E-FA45F4D8D976> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fffbccd0000 -     0x7fffbce17ff7  com.apple.QTKit (7.7.3 - 2974) <DD63A171-2DE6-3210-89B0-BD5991539755> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fffbce18000 -     0x7fffbd083fff  com.apple.imageKit (3.0 - 1016) <A3D24043-95CD-3A40-9850-83E02BDF56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fffbd084000 -     0x7fffbd13dff7  com.apple.PDFKit (1.0 - 1) <32ED1D9C-B9AB-337B-93E5-9DDA8E68F6FB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fffbd13e000 -     0x7fffbd664fff  com.apple.QuartzComposer (5.1 - 351) <10A260C7-A44C-3C64-BF68-FC0FCCD08489> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fffbd665000 -     0x7fffbd688ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <9ECD9812-151A-300D-8F37-F7FEBE67B8BC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fffbd689000 -     0x7fffbd776ff7  com.apple.QuickLookUIFramework (5.0 - 720) <7DBE40A6-3F2F-3AF0-ACF4-8C95B78346C5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fffbd777000 -     0x7fffbd777fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fffbd778000 -     0x7fffbd972ff7  com.apple.QuartzCore (1.11 - 449.39) <B6BEEBAC-2923-3BA6-8DBD-621A2B0E51C1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffbd973000 -     0x7fffbd9c8ff7  com.apple.QuickLookFramework (5.0 - 720) <F54FCBB5-53DD-351D-AAEB-2470CEB30017> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fffbd9c9000 -     0x7fffbd9dcff7  com.apple.SafariServices.framework (12602 - 12602.1.50.0.10) <165467B5-1EE7-325A-8847-0929DC0B81E4> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fffbded8000 -     0x7fffbe1f3fff  com.apple.security (7.0 - 57740.1.18) <AF5E42F1-B513-3410-A5BE-1EC9CBAF8452> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffbe1f4000 -     0x7fffbe26aff7  com.apple.securityfoundation (6.0 - 55132.1.1) <259D4B70-0F8C-3818-99E7-3EBEAA18DE1B> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffbe26b000 -     0x7fffbe293fff  com.apple.securityinterface (10.0 - 55079.1.1) <F6B71377-6CF3-3E55-B20F-77F3C76FC9A4> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fffbe294000 -     0x7fffbe297ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <6A9EA339-BB6A-3DD9-BF08-00B8C0262839> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffbe61c000 -     0x7fffbe68dff7  com.apple.SystemConfiguration (1.14 - 1.14) <C7F21776-2CCE-327B-B155-7A5948277BD6> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffbe68e000 -     0x7fffbea39ff7  com.apple.VideoToolbox (1.0 - 1903.7) <C0044876-9800-3CCA-B7D3-50B92077EF4D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fffc0538000 -     0x7fffc053dff7  com.apple.APFS (1.0 - 1) <F1BD89DF-D84F-3256-905D-6D72706474CF> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fffc0c9b000 -     0x7fffc0cb6ff3  com.apple.AppContainer (4.0 - 307.1.1) <05373DD5-5892-3542-B178-C140F1AB6886> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fffc0cb7000 -     0x7fffc0cc4ff3  com.apple.AppSandbox (4.0 - 307.1.1) <20324EFC-70DC-389D-9C27-37DCAA7E07CC> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fffc0cc5000 -     0x7fffc0ce7ffb  com.apple.framework.Apple80211 (12.0 - 1200.33) <06F8EA45-5E43-3744-BF41-BA86B8BBB5CF> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffc0ce8000 -     0x7fffc0cf7fdb  com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffc0ddf000 -     0x7fffc0e6a97f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffc0e7e000 -     0x7fffc0e99fff  com.apple.aps.framework (4.0 - 4.0) <37A4B7F9-4F43-3A23-B4FC-E7656B5BC73F> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fffc0e9a000 -     0x7fffc0ea2ffb  com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fffc0ea3000 -     0x7fffc0ea6ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6FF50E26-5BDA-3421-BDAE-B57AE6E4F6AC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fffc0ea7000 -     0x7fffc0ef9fff  com.apple.AppleVAFramework (5.0.34 - 5.0.34) <193400A6-B326-3911-BB4F-6C49C1E5FA8F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fffc0f02000 -     0x7fffc0f09ffb  com.apple.AssetCacheServices (31 - 31) <13E874CA-86AB-33E7-A4D8-544D3B8157CD> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fffc1286000 -     0x7fffc1304ff7  com.apple.backup.framework (1.8 - 1.8) <E2888B63-F43C-367F-B23F-7D9F9BD64401> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffc1314000 -     0x7fffc1351ff7  com.apple.bom (14.0 - 193.8) <FAA5CE82-0A87-34C5-A606-81A179009930> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fffc157e000 -     0x7fffc15aafff  com.apple.CacheDelete (1.0 - 1) <2FFDE840-775B-35C8-BE7C-D56F3C149944> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
    0x7fffc1974000 -     0x7fffc199bfff  com.apple.CalendarAgentLink (8.0 - 250) <26CB59F5-7D23-312B-9B1E-EB47D6490A16> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
    0x7fffc1f1e000 -     0x7fffc1f45ffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffc1f46000 -     0x7fffc1fd8ffb  com.apple.CloudDocs (1.0 - 483.2) <9DBD244F-83A0-3593-AA84-313CD5861F2C> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fffc2865000 -     0x7fffc286effb  com.apple.CommonAuth (4.0 - 2.0) <D9958C57-9E97-33F5-A21C-B454FDB11548> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffc2934000 -     0x7fffc2982fff  com.apple.AddressBook.ContactsFoundation (8.0 - 2250) <5588F340-F4A8-3806-8642-08A106421B60> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fffc2983000 -     0x7fffc29a5fff  com.apple.contacts.ContactsPersistence (1.0 - 2250) <524C9EEC-D186-30B2-8A55-CC11A48CC44C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fffc29ef000 -     0x7fffc2dccfe7  com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fffc2dcd000 -     0x7fffc2dfdfff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fffc2e72000 -     0x7fffc2e7affb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fffc2f8a000 -     0x7fffc2f9bfff  com.apple.CoreEmoji (1.0 - 40) <F3D73BF8-6D48-3B1F-BBE6-EE927E725E92> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffc3050000 -     0x7fffc3066fff  com.apple.CoreMediaAuthoring (2.2 - 955) <3B877988-3823-3A84-A083-CE0B5B54F791> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fffc306d000 -     0x7fffc30fdffb  com.apple.CorePDF (4.0 - 4) <42FD0781-A19C-3E36-BFDA-DAEAFB3A3115> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fffc3274000 -     0x7fffc32a4ff3  com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffc352d000 -     0x7fffc35b7fff  com.apple.CoreSymbolication (61050) <BAC8D20F-4DC6-32EE-91FE-BF08E930420A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffc35b8000 -     0x7fffc36f2fef  com.apple.coreui (2.1 - 424.1) <B9B92DB5-1C6C-306F-BD29-B1F82EC95283> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffc36f3000 -     0x7fffc3792ffb  com.apple.CoreUtils (4.3 - 430.70) <87BEB880-3D71-3251-B51E-FF0A42DFC065> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffc37e2000 -     0x7fffc3847ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <D7C870BE-55DE-34AF-8941-D42696D505B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffc3848000 -     0x7fffc3853fff  com.apple.CrashReporterSupport (10.12 - 815) <10C3797E-DD63-303B-B901-1C52A502D2F8> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffc38f9000 -     0x7fffc3970ff3  com.apple.datadetectorscore (7.0 - 539) <C3F6F52B-A1AD-36FA-9BF9-C8D0E147F0A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffc39aa000 -     0x7fffc39e9fff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffc39ea000 -     0x7fffc3afbff7  com.apple.desktopservices (1.11 - 1.11) <494E239D-706F-350B-9481-2A8ECEEDBD8B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffc3b00000 -     0x7fffc3bd6ff7  com.apple.DiskImagesFramework (444 - 444) <F3F87D4C-CD77-3872-87BC-E3E44B1F76ED> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fffc3c3a000 -     0x7fffc3c44fff  com.apple.DisplayServicesFW (3.1 - 380) <79733A44-F60D-3EC0-BBC7-C4AEC5649D8F> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fffc3c89000 -     0x7fffc3c8bffb  com.apple.EFILogin (2.0 - 2) <C53AC3A4-C684-3144-89A4-166549518C24> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fffc3dc6000 -     0x7fffc41f7ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffc4232000 -     0x7fffc45a9ff7  com.apple.FinderKit (1.5 - 1.5) <987D147E-0BA6-3331-81FA-382440E0E3B3> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
    0x7fffc5530000 -     0x7fffc5530fff  libmetal_timestamp.dylib (600.0.48.25) <348D32E6-AD49-36DC-A0DE-5A44B2699FFA> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffc553d000 -     0x7fffc5548ff3  libGPUSupportMercury.dylib (12.4.2.1) <A720545E-40F3-3FE0-A8B3-067D49083417> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffc57fa000 -     0x7fffc5816ff7  com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffc582e000 -     0x7fffc5ec2fff  com.apple.GeoServices (1.0 - 1226.20.7.17.11) <A6007FBD-25F7-3F52-972A-EEFCE0F6BF70> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fffc5f08000 -     0x7fffc5f7efff  com.apple.Heimdal (4.0 - 2.0) <18C127D7-9C61-3C5B-8C6F-7953760D2674> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffc5f7f000 -     0x7fffc5f90fff  com.apple.HelpData (2.1.10 - 100) <BD5AC3F0-9619-3D1C-B96D-6BFCAD1C0245> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fffc6590000 -     0x7fffc6597ffb  com.apple.IOAccelerator (288.13 - 288.13) <F77E27C3-20DD-3CE5-9D0A-6C89A997080E> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffc6599000 -     0x7fffc65adff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffc65ae000 -     0x7fffc65d0ff7  com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffc666b000 -     0x7fffc667bff3  com.apple.IntlPreferences (2.0 - 216) <43FFAB0C-4124-3231-B0CB-137CCB0A53AF> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fffc669a000 -     0x7fffc66a7fff  com.apple.KerberosHelper (4.0 - 1.0) <B4AADAF1-5E4F-3654-8377-045BF992C63C> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
    0x7fffc66b2000 -     0x7fffc6866fff  com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffc6888000 -     0x7fffc688cffb  com.apple.LoginUICore (4.0 - 4.0) <7CE3F5E8-E365-31D0-97C9-A54A7F336D67> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fffc6936000 -     0x7fffc6a07ff3  com.apple.MMCS (1.3 - 379) <14867D2F-6E87-351E-AB4B-9BD759364DFD> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fffc6e9d000 -     0x7fffc6ea0fff  com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fffc6f78000 -     0x7fffc6facff3  com.apple.MediaKit (16 - 840) <2035FF47-C7E6-3F73-A335-AC0BFBB1DB36> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fffc6fad000 -     0x7fffc70b8ff7  com.apple.MediaRemote (1.0 - 1) <0F9ECD8D-236E-3098-AE17-B34806FB31AE> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
    0x7fffc70b9000 -     0x7fffc70d8ffb  com.apple.MediaServices (1.0 - 1) <C33996B9-1267-39EB-B08D-6107CDB4F327> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
    0x7fffc70fc000 -     0x7fffc7174fef  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <FAFA0DF5-4226-3867-A2E2-CAB889DC4490> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffc72da000 -     0x7fffc72e5ff7  com.apple.MobileKeyBag (2.0 - 1.0) <7ECC9D0A-246F-3D7E-9E78-16DBA0B55F49> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fffc72f6000 -     0x7fffc731cfff  com.apple.MultitouchSupport.framework (367.6 - 367.6) <32D8588A-29BD-3A23-92B2-05C013DA5BC5> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffc73c9000 -     0x7fffc73d3fff  com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffc77c8000 -     0x7fffc77cafff  com.apple.OAuth (25 - 25) <1A29AF10-4AFE-32A2-9CA9-A98BACA2CE8D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fffc7b74000 -     0x7fffc7bb5ff7  com.apple.PerformanceAnalysis (1.145 - 145) <9DF1FCCC-7EBF-3213-B77A-0C3D3B7CF7AF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffc7bf9000 -     0x7fffc7c00ff3  com.apple.phonenumbers (1.1.1 - 105) <14003B00-D2DA-3732-A1AC-A71763EC3556> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fffc81b0000 -     0x7fffc81d2ff3  com.apple.pluginkit.framework (1.0 - 1) <966D5575-E092-33A4-8CD8-595EB6AA637A> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fffc8219000 -     0x7fffc8244ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <A1219818-97B0-3A4D-825B-24ADF9B7C8B6> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fffc8245000 -     0x7fffc825ffff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffc8260000 -     0x7fffc8270ffb  com.apple.QuickLookThumbnailing (1.0 - 1) <DD5F14E6-A8A8-3EA8-96A3-4C84092BC18F> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fffc8279000 -     0x7fffc829cff3  com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffc8ecb000 -     0x7fffc8eceff7  com.apple.SecCodeWrapper (4.0 - 307.1.1) <64F951CB-A975-32F0-BC60-1E839E607FCB> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fffc8f5c000 -     0x7fffc8fd7fff  com.apple.Sharing (659.1.6 - 659.1.6) <C217107C-CD4B-311D-9FBA-7435B1F6186F> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffc8fd8000 -     0x7fffc8ff7ff7  com.apple.shortcut (2.16 - 98) <AC3AFB42-F3F7-3E71-8DAF-AA4ACF3021F7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fffc8ff8000 -     0x7fffc9259ff3  com.apple.SkyLight (1.600.0 - 100) <F0B08B4C-8550-3241-8128-F7601E60BDEB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffc9433000 -     0x7fffc943ffff  com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffc97c2000 -     0x7fffc9821ffb  com.apple.Suggestions (6.0 - 194) <1504D99A-18FE-3151-B671-8FC4BA6F58F4> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
    0x7fffc9b22000 -     0x7fffc9b8eff3  com.apple.Symbolication (61080.2) <0F183B36-0BCF-3330-8C68-4A521A142919> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffc9d77000 -     0x7fffc9da3ff3  com.apple.framework.SystemAdministration (1.0 - 1.0) <DAD14404-CA3E-3D5E-9470-D28E42CC1948> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fffc9f85000 -     0x7fffc9f8bff7  com.apple.TCC (1.0 - 1) <CEE9F9F9-2A24-3F60-BE73-4703D85E307C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffca017000 -     0x7fffca1caff3  com.apple.TextureIO (1.31 - 1.31) <9E6E91C7-76DC-3C12-9629-494084792476> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffca213000 -     0x7fffca228ff3  com.apple.ToneKit (1.0 - 1) <ACFC15FF-6BB9-3D0F-B94E-617E9D1362DA> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fffca229000 -     0x7fffca237ffb  com.apple.ToneLibrary (1.0 - 1) <32AD3F5C-124F-351D-BC9B-63A7AEA20F31> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fffca23e000 -     0x7fffca23ffff  com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffca240000 -     0x7fffca3cfffb  com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffcae2a000 -     0x7fffcaed9ff7  com.apple.ViewBridge (265.1 - 265.1) <21855FE3-F19D-3E3F-9500-BFC811DA75C6> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fffcb301000 -     0x7fffcb307fff  com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fffcb354000 -     0x7fffcb3d2ff7  com.apple.iLifeMediaBrowser (2.11.0 - 731) <7DBE70BF-3D84-3023-97BA-9387CC502C59> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
    0x7fffcb3d8000 -     0x7fffcb3daffb  com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffcb406000 -     0x7fffcb42dff3  com.apple.contacts.vCard (1.0 - 2250) <443AB8FC-1C0F-3505-8C90-CDE600C9C73E> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fffcb42f000 -     0x7fffcb44aff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
    0x7fffcb44b000 -     0x7fffcb456fff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
    0x7fffcb457000 -     0x7fffcb4e7ff7  libCoreStorage.dylib (540) <767EE749-FAD4-3557-ACC8-35EF8457B98D> /usr/lib/libCoreStorage.dylib
    0x7fffcb4e8000 -     0x7fffcb4e9ff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffcb4ea000 -     0x7fffcb6fdfff  libFosl_dynamic.dylib (16.37) <3EA1C7EE-4A6C-3B09-BCA7-81A074B24013> /usr/lib/libFosl_dynamic.dylib
    0x7fffcb719000 -     0x7fffcb720fff  libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
    0x7fffcb721000 -     0x7fffcb721fff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffcb722000 -     0x7fffcb725ff7  libScreenReader.dylib (477.1.5) <88D484EC-7589-324B-890D-799F27DF0FB3> /usr/lib/libScreenReader.dylib
    0x7fffcb726000 -     0x7fffcb727ff3  libSystem.B.dylib (1238) <168B3C56-081B-3998-9A44-681EB4C6828F> /usr/lib/libSystem.B.dylib
    0x7fffcb793000 -     0x7fffcb7beffb  libarchive.2.dylib (41.1.1) <C4F76D18-8484-3779-AE80-14F27E57ABB5> /usr/lib/libarchive.2.dylib
    0x7fffcb7bf000 -     0x7fffcb899fe7  libate.dylib (1.12.12) <1371D20C-3A80-37A5-AB94-09C4C4F67B01> /usr/lib/libate.dylib
    0x7fffcb89d000 -     0x7fffcb89dff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
    0x7fffcb89e000 -     0x7fffcb8aeff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffcb8af000 -     0x7fffcb8bdff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
    0x7fffcb8be000 -     0x7fffcb914ff7  libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
    0x7fffcb915000 -     0x7fffcb93ffff  libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
    0x7fffcb940000 -     0x7fffcb950ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffcb951000 -     0x7fffcb966ffb  libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
    0x7fffcb967000 -     0x7fffcb967ff7  libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib
    0x7fffcb968000 -     0x7fffcb969ffb  libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffcba23000 -     0x7fffcbb07ff3  libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffcbc99000 -     0x7fffcbca4fff  libcsfde.dylib (540) <0F49D756-17BF-3E69-AD3B-A9B993CD41EA> /usr/lib/libcsfde.dylib
    0x7fffcbca5000 -     0x7fffcbcf8ff7  libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib
    0x7fffcbcf9000 -     0x7fffcbd48ff7  libcurl.4.dylib (95) <7FFE0024-36CD-3040-923F-1DE911FE5459> /usr/lib/libcurl.4.dylib
    0x7fffcbd49000 -     0x7fffcbd50ff3  libdscsym.dylib (145) <0972B577-B427-3A1C-A9E7-325B6B265135> /usr/lib/libdscsym.dylib
    0x7fffcbd72000 -     0x7fffcbd72fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffcbd82000 -     0x7fffcbd87ff3  libheimdal-asn1.dylib (498) <8F3F1AE8-CE4A-355C-82E3-74DA46B5BB02> /usr/lib/libheimdal-asn1.dylib
    0x7fffcbd88000 -     0x7fffcbe7aff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffcbe7b000 -     0x7fffcc0a0fff  libicucore.A.dylib (57131.0.1) <72594943-D25E-3F70-A4AC-8E9F9F442B7E> /usr/lib/libicucore.A.dylib
    0x7fffcc0a6000 -     0x7fffcc0a7fff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
    0x7fffcc0a8000 -     0x7fffcc0c1ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffcc0c2000 -     0x7fffcc0d8ff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
    0x7fffcc0d9000 -     0x7fffcc382fff  libmecabra.dylib (744) <545EDC2D-22BB-3E8F-BFD3-921447581D9F> /usr/lib/libmecabra.dylib
    0x7fffcc3b5000 -     0x7fffcc42dffb  libnetwork.dylib (856.1.8) <30FC3C60-CCA9-3E2B-80AA-DE53F5762374> /usr/lib/libnetwork.dylib
    0x7fffcc42e000 -     0x7fffcc803127  libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
    0x7fffcc804000 -     0x7fffcc805ff7  libodfde.dylib (23) <4DFCC459-2C07-38C6-871F-94DA3677F1EA> /usr/lib/libodfde.dylib
    0x7fffcc806000 -     0x7fffcc80afff  libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib
    0x7fffcc80b000 -     0x7fffcc83bff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
    0x7fffcc859000 -     0x7fffcc875ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffcc876000 -     0x7fffcc8affff  libsandbox.1.dylib (592.1.3) <0024D751-23D8-35DF-87CF-72E489DA2F9F> /usr/lib/libsandbox.1.dylib
    0x7fffcc8b0000 -     0x7fffcc8c2ffb  libsasl2.2.dylib (209) <5A177BA8-362D-32DA-8D14-69AB191648B3> /usr/lib/libsasl2.2.dylib
    0x7fffcc8c3000 -     0x7fffcc8c4ff3  libspindump.dylib (228) <F80FAB75-D656-3FDA-8753-D3D6771B17E6> /usr/lib/libspindump.dylib
    0x7fffcc8c5000 -     0x7fffcca06ffb  libsqlite3.dylib (252) <A531C105-64D7-37C0-B999-9320047B71C5> /usr/lib/libsqlite3.dylib
    0x7fffcca29000 -     0x7fffcca61ff3  libssl.0.9.8.dylib (64) <CCE69718-2965-3E28-A886-41C79EB94C67> /usr/lib/libssl.0.9.8.dylib
    0x7fffcca62000 -     0x7fffccab2fff  libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
    0x7fffccaf4000 -     0x7fffccaf6ffb  libutil.dylib (47) <2E56EB36-BF20-3261-9083-3D7AD06A96A2> /usr/lib/libutil.dylib
    0x7fffccaf7000 -     0x7fffccb04fff  libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib
    0x7fffccb08000 -     0x7fffccbf7ffb  libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib
    0x7fffccbf8000 -     0x7fffccc21fff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
    0x7fffccc22000 -     0x7fffccc33ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffccc42000 -     0x7fffccc46ff7  libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib
    0x7fffccc47000 -     0x7fffccc51fff  libcommonCrypto.dylib (60092.1.2) <79F738D8-0AD7-3DEA-AF80-E0F8B90B74E3> /usr/lib/system/libcommonCrypto.dylib
    0x7fffccc52000 -     0x7fffccc59fff  libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib
    0x7fffccc5a000 -     0x7fffccc62fff  libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib
    0x7fffccc63000 -     0x7fffccce5ff3  libcorecrypto.dylib (442.1.3) <1CA8B679-810E-3C04-945A-4AC19372CDC7> /usr/lib/system/libcorecrypto.dylib
    0x7fffccce6000 -     0x7fffccd18fff  libdispatch.dylib (703.1.4) <12B1D95B-283D-325D-85AB-29A2FFD36987> /usr/lib/system/libdispatch.dylib
    0x7fffccd19000 -     0x7fffccd1eff3  libdyld.dylib (421.1) <CDFBDC9C-418C-369D-B433-F64B0630E640> /usr/lib/system/libdyld.dylib
    0x7fffccd1f000 -     0x7fffccd1fffb  libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib
    0x7fffccd20000 -     0x7fffccd2cffb  libkxld.dylib (3789.1.32) <48BDBE7F-AAE6-3050-9017-6959051CF16A> /usr/lib/system/libkxld.dylib
    0x7fffccd2d000 -     0x7fffccd2dfff  liblaunch.dylib (972.1.5) <DC31FDEA-FD81-335E-BAA8-5A7395D20772> /usr/lib/system/liblaunch.dylib
    0x7fffccd2e000 -     0x7fffccd33fff  libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib
    0x7fffccd34000 -     0x7fffccd36ff3  libquarantine.dylib (85) <78EF62D8-C890-3FC0-937A-C2FD8CEF8992> /usr/lib/system/libquarantine.dylib
    0x7fffccd37000 -     0x7fffccd38ffb  libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib
    0x7fffccd39000 -     0x7fffccd51ff7  libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib
    0x7fffccd52000 -     0x7fffccd52ff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
    0x7fffccd53000 -     0x7fffccde0fe7  libsystem_c.dylib (1158.1.2) <5F260836-48E4-3F57-8553-62D2DA228A1F> /usr/lib/system/libsystem_c.dylib
    0x7fffccde1000 -     0x7fffccde4ffb  libsystem_configuration.dylib (888.1.2) <67BB9D8B-2430-38AD-81A7-F0EC924B2590> /usr/lib/system/libsystem_configuration.dylib
    0x7fffccde5000 -     0x7fffccde8fff  libsystem_coreservices.dylib (41.1) <11F22E6C-0DCB-3699-A4F0-C99E301E56E9> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffccde9000 -     0x7fffcce01ffb  libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib
    0x7fffcce02000 -     0x7fffcce08fff  libsystem_dnssd.dylib (765.1.2) <C5FF2025-C60B-39C6-B205-6BF1BC51D1B3> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffcce09000 -     0x7fffcce32fff  libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib
    0x7fffcce33000 -     0x7fffcce55ff7  libsystem_kernel.dylib (3789.1.32) <5C68A0D7-C3C9-3E52-B983-EDE9A28AB6FC> /usr/lib/system/libsystem_kernel.dylib
    0x7fffcce56000 -     0x7fffcce9dfe7  libsystem_m.dylib (3121.4) <E3370D16-EBAA-3C7F-AC56-2D6EAD7DB0A4> /usr/lib/system/libsystem_m.dylib
    0x7fffcce9e000 -     0x7fffccebcff7  libsystem_malloc.dylib (116) <3DD17B88-B7A4-38B9-9E95-AB88E1C3B647> /usr/lib/system/libsystem_malloc.dylib
    0x7fffccebd000 -     0x7fffccf13fff  libsystem_network.dylib (856.1.8) <A8973360-956A-33BF-9971-14D59C84E0D1> /usr/lib/system/libsystem_network.dylib
    0x7fffccf14000 -     0x7fffccf1dff3  libsystem_networkextension.dylib (563.1.11) <1C551832-9360-36DD-A7BA-52B55A171720> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffccf1e000 -     0x7fffccf27ffb  libsystem_notify.dylib (165) <AF77D471-6B13-36BA-B144-7E7DDB9DBA9F> /usr/lib/system/libsystem_notify.dylib
    0x7fffccf28000 -     0x7fffccf30fe7  libsystem_platform.dylib (126.1.2) <884DDF42-3CAE-334A-82CE-965617130FB1> /usr/lib/system/libsystem_platform.dylib
    0x7fffccf31000 -     0x7fffccf3bfff  libsystem_pthread.dylib (218.1.3) <050AE77B-4F4B-334A-A5BA-CF0D10AF5304> /usr/lib/system/libsystem_pthread.dylib
    0x7fffccf3c000 -     0x7fffccf3ffff  libsystem_sandbox.dylib (592.1.3) <90FEF628-316D-3F84-9EF4-F7F510A4FBBB> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffccf40000 -     0x7fffccf41fff  libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib
    0x7fffccf42000 -     0x7fffccf49fff  libsystem_symptoms.dylib (532.1.1) <B26F656E-94F9-3834-9B03-51C4FF11D1BF> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffccf4a000 -     0x7fffccf6aff7  libsystem_trace.dylib (518.1.16) <C3CDF7BC-CA3D-34F5-ADF8-46AAAB0B47F8> /usr/lib/system/libsystem_trace.dylib
    0x7fffccf6b000 -     0x7fffccf70ffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
    0x7fffccf71000 -     0x7fffccf9aff7  libxpc.dylib (972.1.5) <2A901937-48E1-3BF2-83F1-2431156D82B7> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 3
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 175327
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=515.8M resident=0K(0%) swapped_out_or_unallocated=515.8M(100%)
Writable regions: Total=2.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.0G(100%)
                                  VIRTUAL   REGION
REGION TYPE                          SIZE    COUNT (non-coalesced)
ATS (font support)                  32.1M        9
ATS (font support) (reserved)          4K        2         reserved VM address space (unallocated)
Accelerate framework                 512K        5
Activity Tracing                     256K        2
CG backing stores                  148.5M       20
CG image                            1812K       87
CoreAnimation                        584K       24
CoreUI image data                   5044K       36
CoreUI image file                    312K        6
Foundation                            32K        3
Image IO                              28K        6
JS JIT generated code                  8K        3
JS JIT generated code (reserved)     1.0G        2         reserved VM address space (unallocated)
JS VM register file (reserved)      4096K        2         reserved VM address space (unallocated)
JS garbage collector                 256K        3
Kernel Alloc Once                      8K        2
MALLOC                             786.5M      234
MALLOC guard page                     48K       10
Memory Tag 242                        12K        2
Memory Tag 251                        60K        4
OpenCL                                40K        6
SQLite page cache                     64K        2
STACK GUARD                         56.1M       18
Stack                               16.1M       18
VM_ALLOCATE                         2752K       51
WebKit Malloc                       1232K       14
__DATA                              50.6M      432
__GLSLBUILTINS                      2588K        2
__IMAGE                              528K        2
__LINKEDIT                         131.7M      104
__TEXT                             384.2M      404
__UNICODE                            556K        2
mapped file                        194.2M       65
shared memory                       16.4M       19
TOTAL                                2.8G     1567
TOTAL, minus reserved VM space       1.8G     1567
Model: MacBookPro10,1, BootROM MBP101.00EE.B0A, 4 processors, Intel Core i7, 2.6 GHz, 8 GB, SMC 2.3f36
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (7.21.171.10.1a16)
Bluetooth: Version 5.0.0f18, 3 services, 27 devices, 1 incoming serial ports
Network Service: Thunderbolt Ethernet, Ethernet, en3
Network Service: Wi-Fi, AirPort, en0
PCI Card: Apple 57762-A0, Ethernet Controller, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SM512E, 500.28 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: DT Ultimate G2
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
Thunderbolt Device: Thunderbolt to Gigabit Ethernet Adapter, Apple Inc., 3, 5.5
Re: Constant crashes and can't apply updates. Frustrated.
« Reply #23 on: 2016 October 14 10:09:38 »
Thank you for your reports. I cannot reproduce these problems on any of our working machines with OS X 10.10 and 10.11, but have some comments:
Lightpath: The update process requires read/write permissions granted on the /Applications folder. In practice this means that in order to apply an update, you must have some administrative rights. I plan on fixing this limitation in the next 1.8.5 version, but it applies to 1.8.4. I don't know if solving this permissions issue would fix all problems for you. I suspect there is more in your case, probably a conflict with other software running on your computer.
Andrei: Please note that macOS 10.12 Sierra is not an officially supported platform. That said, many users are running version 1.8.4.1199 without problems on macOS 10.12 (even 1.8.4.1195 on upgraded systems). From your report, the issue looks like a bug in system libraries, not in PixInsight. The sequence:
0   libsystem_kernel.dylib           0x00007fffcce4cdda __pthread_kill + 10
1   libsystem_pthread.dylib          0x00007fffccf37797 pthread_kill + 90
2   libsystem_c.dylib                0x00007fffccdb2440 abort + 129
3   libc++abi.dylib                  0x00007fffcb91685a abort_message + 266
4   libc++abi.dylib                  0x00007fffcb93bc4f default_terminate_handler() + 267
5   libobjc.A.dylib                  0x00007fffcc444ba3 _objc_terminate() + 124
6   libc++abi.dylib                  0x00007fffcb938d69 std::__terminate(void (*)()) + 8
7   libc++abi.dylib                  0x00007fffcb9389f2 __cxa_rethrow + 99
8   libobjc.A.dylib                  0x00007fffcc442f07 objc_exception_rethrow + 40
9   com.apple.CoreFoundation         0x00007fffb7c4c8fb CFRunLoopRunSpecific + 555
10  com.apple.HIToolbox              0x00007fffb71ecf6c RunCurrentEventLoopInMode + 240
11  com.apple.HIToolbox              0x00007fffb71ecda1 ReceiveNextEventCommon + 432
12  com.apple.HIToolbox              0x00007fffb71ecbd6 _BlockUntilNextEventMatchingListInModeWithFilter + 71
clearly shows that the crash has happened outside of PixInsight and Qt code, most likely in the CoreFoundation system component. This is not too surprising since Sierra is pretty new. _BlockUntilNextEventMatchingListInModeWithFilter is part of an event loop routine. It simply waits for the next system event (for example, when you press a key or move the mouse). The ReceiveNextEventCommon routine dispatches the new event. From this point, the crash has nothing to do with our code.
Do you get this crash on a repeatable basis, or is it sporadic?
Offline Andrei Ioda
« Reply #24 on: 2016 October 14 10:14:16 »
Sporadic, during 15-20 minutes after start of PixInsight. I had the same issue on 10.11 too.
P.S. I have the same error message as in this topic - http://pixinsight.com/forum/index.php?topic=10333.msg65064#msg65064
« Reply #25 on: 2016 October 14 10:20:21 »
Then I have no idea of what happens here. Could be hardware-related. As I said, this does not happen on any of our working and testing machines with OS X 10.10 and 10.11. I have no machine with 10.12 yet, so I cannot test the application on that OS version (and hence can't support it officially).
Offline Andrei Ioda
« Reply #26 on: 2016 October 14 11:09:09 »
I have attached the screenshot with error message.
Offline Lightpath
« Reply #27 on: 2016 October 14 23:34:25 »
The waters are somewhat muddy now, with troubleshooting two issues in the same thread, but perhaps they are related.
I am actually having good luck with PixinSight tonight, hopefully my luck holds out, I'll let you know.  I'm trying to narrow down what application PixinSight doesn't cooperate with, I suspect it's Norton Antivirus but I am not 100% sure.
Is there any troubleshooting you would like me to do to see if I can get some more advanced information?
Do you have Norton Antivirus installed on your test systems?
« Reply #28 on: 2016 October 15 01:20:01 »
No, we don't use any antivirus on our OS X machines. They are strongly protected in our local network and we use them exclusively for development and intensive testing purposes. We only use virus protection software (McAfee Internet Security) on our physical and virtual Windows machines.
Antivirus applications have always caused problems on Windows. See for example FAQ 3.9 as a good example of the kind of problems caused by antivirus applications 'protecting' users 'creatively':
http://pixinsight.com/faq/
Similar problems have been reported since we released the first version of PixInsight. In most cases they are generated by poor-quality virus protection and firewall software. For example, when we released the first version of the XISF format support module, we received many complaints from Windows users that fit perfectly in FAQ 3.9. The reason is simply that 'XISF-pxm.dll' is an unknown file name for some antivirus programs that consider it dangerous for some reason... go figure why. These complaints are rare presently.
In my opinion, antivirus software may or may not be necessary on OS X, mainly as a function of the user's behavior on the Internet. Contrarily, it is absolutely necessary on Windows, mainly because of its inherent weakness, and also because of the huge amount of existing attacks and threats against Windows machines, including the large amount of freeware, shareware and pirated applications that come with 'little gifts'. In any case, antivirus software is always a source of potential problems, especially for a highly modular and dynamic software platform such as PixInsight.
Offline Andrei Ioda
« Reply #29 on: 2016 October 16 23:16:36 »
I don't have any antivirus software.
