Author Topic: Continuing problems with Mosaics.  (Read 3407 times)
Offline Robert Q. Kimball
« on: 2016 October 04 13:08:10 »
Hello,
I am fairly experienced with PixInsight but continue to have problems with building a mosaic from four panels.  Earlier a participant, pfile, gave me some great advice, but I still can't get my a mosaic from my data.  I have watched "Creating a Seamless Supermosaic, by Steve Allan" on YouTube many time and completely understand it.  I just can't get it to work.
First, all of my four panel can be registered in pairs, ( ie. 1+2, 2+4,4+3, and 3+1)  there is no problem with star registration.
Here is what happen. Each time I add a panel to the mosaic, the added panel is "redder" than the first panel.  by the time I add the fourth panel the image is very, very red.  Each added panel seems to have a more blurry noise background.
Here are links to the four panels.  Any help would be appreciated.
https://www.dropbox.com/s/2g33nlxlo8axb69/Heart_Panel_1_DBE.xisf?dl=0
https://www.dropbox.com/s/14gy55gg4t895p0/Heart_Panel_2_DBE.xisf?dl=0
https://www.dropbox.com/s/bobrfc8tlfvyoty/Heart_Panel_3_DBE.xisf?dl=0
https://www.dropbox.com/s/8x710o300nnx7ro/Heart_Panel_4_DBE.xisf?dl=0
Bob
Re: Continuing problems with Mosaics.
« Reply #1 on: 2016 October 04 14:24:25 »
i successfully made a mosaic from the data. i first used the dnaLinearFit script to match the brightness of each frame. 1 as reference to 3 and 2, then 3 to 4.
i then used staralignment in mosaic mode to build the mosaic; 3 as reference to 1, then the combined as reference to 4, then the combined as reference to 2. it turned out that the dnaLinearFit was not perfect, so i turned on 'frame adaptation' in star alignment and did it all again.
p.s. there is some problem with panel 4 - horizontal streaks in the stars. there must have been a bad frame in the integration.
[the xisf is uploading, i'll edit the post when it's done.]
https://drive.google.com/file/d/0B6cW4ae2KyMJNXVrNUdzX0NEdEU/view?usp=sharing
« Last Edit: 2016 October 04 14:38:39 by pfile »
« Reply #2 on: 2016 October 04 15:50:12 »
pfile,
Thank you again.  I'll see if I can duplicate your effort.  I'll figure out dnaLinearFit!  Now I owe you two beers in Las Cruces!
Bob
« Reply #3 on: 2016 October 04 16:04:44 »
Feeling like an idiot.  How do I get dnaLinearFit?
Bob
« Reply #4 on: 2016 October 04 16:12:27 »
its a script written by david ault:
http://trappedphotons.com/blog/?p=994
middle of the page, under "intensity matching"
dnaLinearFit might not be necessary - did you use frame adaptation when you made your attempt? i didn't try skipping the dnaLinearFit step so i'm not sure if it helped SA get a better result when doing frame adaptation.
Offline gvanhau
« Reply #5 on: 2016 October 06 11:09:53 »
Hello Bob
A different aproach would be:
Generate a star field the size of your whole mosaic, then register all the tiles to if.
finally use gradient merge mosaic to combine the registerd tiles.
Regards
Geert
Geert Vanhauwaert
« Reply #6 on: 2016 October 06 12:21:47 »
Hello Experts!
I still can't get a good mosaic from my panels.
I have put together matrix images before without any problems.  I think my problem has to do with my use of SGPro as my capture program.    When I use Artemis my debayer matrix was BGGR.  I was surprised that when I switched to SGPro the matrix changed to GRBG.  Whether this has any relationship to my mosaic issue I don't know.
I have tried to simplify my issue with new, better data.  I appreciate the help I've already received for Rob (pfile) and others.
Here are two panels each the integration of 4 X 10 min images with an Atik 3833L OSC camera.  I have carefully used DBE, Background Neutralization and Color Calibration to get them very similar in intensity.
https://www.dropbox.com/s/9d4im49ruamhmgm/Panel_1_DBE.xisf?dl=0
https://www.dropbox.com/s/rg6n6irxecj7tpv/Panel_2_DBE.xisf?dl=0
Then I did a Star Alignment using Mosaic/Union.  If you look closely at the resulting mosaic, the two images are very different in "background texture".  This didn't happen when I did the same type of combination with images captured using Atik's capture program Artemis.
https://www.dropbox.com/s/ol2lcmf4030lfmg/Mosaic.xisf?dl=0
The more panels I add the "creamier" the background gets.
I have also tried the Gradient Merge tool on this data and got terrible results.
Any help is welcome.
Bob
Offline chris.bailey
« Reply #7 on: 2016 October 07 00:42:28 »
Strange, I get very different results from using using the parameters below, the result is pretty much seamless??
I find Star Alignment - Union/Mosaic with Frame Adaptation and Distortion Correction works pretty well for two panel mosaics. Its when you get to 4 and above that more complex methods are called for.
Chris
« Reply #8 on: 2016 October 07 18:00:26 »
Thanks for your reply.  It does look a lot better with 2-D Spline.  I hadn't tried that.
Bob
