Author Topic: *** Error: RANSAC: Unable to find a valid set of star pair matches.  (Read 3700 times)
Offline Leandro VARGAS
Hello,
After any weeks in different session with one number important of picture in BPP, I have the error *** Error: RANSAC: Unable to find a valid set of star pair matches.
I saw the pictures with problem, but I can't discovery the problem, I saw older post in the Forum, but is not clear.
Please, help me.
Thank you,
Leandro
« Last Edit: 2016 October 02 17:20:11 by Leandro VARGAS »
Offline John_Gill
In the BatchPreProcessing script, under the "Lights" tab is a setting called "Image Registration".  Then Select "Noise Reduction" and set to 1 and try to restack the images.  If you still have issues then up the value to 2 or 3.  I have had to use 5, but then my image becomes very "grainy"
Hope this helps.
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Thank you John,
I will try the option this week.
Leandro
