Author Topic: DBE Result  (Read 5371 times)
Offline Singlin
Re: DBE Result
« Reply #15 on: 2016 September 13 14:22:55 »
I beg your pardon you are right.
How do you find the correct DBE settings for a given image?
Re: DBE Result
« Reply #16 on: 2016 September 13 14:51:49 »
In this case the more important thing is to place the samples where there are no stars. If you see your previously posted image, it has dark areas. That is because there were samples covering stars or bright parts of the nebula.
It is useful that you apply a simple DBE first on an auxiliary image to have a better visualization of where you place the samples. Once all the samples have been placed, generate the icon and reopen it on the original image.
To generate the samples, you can both, apply them one by one, or Generate a considerable amount of them setting the number in the "samples per row" box in the Sample Generation section, and then check one by one to move them away from stars or bright nebula areas.
In this case I only have increased the Tolerance parameters. That was to be allowed to place samples in the bright parts of the image (if you do not increase it, you will see that the sample is red, which is a bad sample)
You can see also this video regarding DBE.
hope this helps
Offline Singlin
Re: DBE Result
« Reply #17 on: 2016 September 13 14:55:10 »
Thank you very much.
You have been very helpfull,much appreciated.
Simon
www.lesrochers.com
Re: DBE Result
« Reply #18 on: 2016 September 13 15:04:44 »
well i know where i'm going on vacation in europe  O0
Re: DBE Result
« Reply #19 on: 2016 September 13 15:54:15 »
far away from here but I will also have in mind  ;)
