Author Topic: Best choice for software binning  (Read 2769 times)
Offline lucchett
« on: 2016 August 20 20:59:07 »
I have some rgb binning 1x1 and I'd like to bin them via software . What is the best procedure?
Thank you, Andrea
Offline vicent_peris
    • http://www.astrofoto.es/
Re: Best choice for software binning
« Reply #1 on: 2016 August 21 00:32:52 »
If you want to apply a strict software binning, then the tool is IntegerResample, as it will simply average pixel values without applying any interpolation algorithm. For instance, it's very useful to generate binned master flats from bin 1x1 masters.
Best regards,
Vicent.
Offline lucchett
« Reply #2 on: 2016 August 21 08:37:53 »
Thank you Vicent, that's what I was looking for.
Best , Andrea
« Reply #3 on: 2016 August 21 13:28:41 »
Please keep in mind that you should subtract the bias from the flats when both images are at binning 1x1. After that, you can then downsize the flat field. You can even integrate all the flats to a master flat at binning 1x1 and then resample to 2x2.
Best regards,
Vicent.
Offline lucchett
« Reply #4 on: 2016 August 21 20:17:57 »
Yes, got it.
I can acquire bias remotely, no problem.
Thanks Andrea
