Author Topic: Moving Images to another PC during processing...  (Read 2518 times)
Offline rjbokleman
    • Astrobin
« on: 2016 August 10 15:18:14 »
...results in the image file location being stored somewhere so you can't finish things off.
If you start on a low power laptop for example and have the files stored in C:\Users\<username>\Documents\ and later move the entire folder to a higher powered machine to finish the processing when you get to the Drizzle integration if FAILS because it can't find the original file location.  Storing file locations in files/projects is just such bad programing practice...
Offline Geoff
Re: Moving Images to another PC during processing...
« Reply #1 on: 2016 August 10 15:28:32 »
You should save your work as a project (file>save project) and then transfer the xosm files across.
Don't panic! (Douglas Adams)
« Reply #2 on: 2016 August 13 01:57:36 »
This has already been answered before:
http://pixinsight.com/forum/index.php?topic=9832.0
If you specify an input directory in the DrizzleIntegration tool, it will override file directories stored in .drz files. It's that simple.
Criticizing the work and programming practices of others is delicate; one should always double-check one's arguments before doing that.
Offline rjbokleman
    • Astrobin
« Reply #3 on: 2017 March 01 17:41:03 »
Juan, et al
I do appreciate the help.  Don't get me wrong.  I, like many, am a big fan of PI.  The support you and the community provide is amazing for the price of the software.
However, if the application didn't store these values, then the Input Directory override wouldn't be necessary as a workaround.  I'd still like to see this become an unnecessary feature of the tool down the road, but now that I know about it, it's less of an issue.
