Author Topic: Processing for Cat's Eye Nebula?  (Read 4291 times)
Offline KuriousGeorge
« on: 2016 July 31 10:53:02 »
Hi folks, I'm starting processing on the Cat's Eye Nebula (attached). I believe the core in the 32-bit stretched .fit file is preserved. If so, is there some way I can say "If the pixel value if greater than X then multiply by Y" ?
If something already exists, that would be great! Just trying to apply a simple stretch and fix the core. It seems difficult to do the opposite (i.e., keep the core down and stretch the rest).
Offline aworonow
    • Faint Light Photography
Re: Processing for Cat's Eye Nebula?
« Reply #1 on: 2016 July 31 12:42:17 »
An exponential stretch can be expressed as 1-(1-$T)^n, where n > 0 and $T represents the pixel values in the image that you drop the triangle on. So, in PixelMath,
if ($T>a, 1-(1-$T)^n, $T)
where "a" is you lower limit of intensity for applying the stretch. You can define the values for a and n in the symbols tab.
Alternatively, you could adjust the stretch using CurvesTransformation.
cheers. Alex
« Reply #2 on: 2016 July 31 12:53:25 »
Thanks Alex!
A few quick questions:
1. I enter the above equation in PixelMath > RGB/K. I get the error "Unknown function identifier: if ($T>a, 1-(1-$T)^n, $T)
2. What is the range for "a" for a 32-bit monochrome .fit file?
3. What is "n" for no effect and n for maximum effect?
« Last Edit: 2016 July 31 15:22:20 by KuriousGeorge »
« Reply #3 on: 2016 July 31 21:57:56 »
"if" should be "iif"
Offline Cosmick
« Reply #4 on: 2016 August 01 02:49:15 »
HDRMultiscaleTransform is designed for this purpose. It will usually work pretty well after transferring the default STF to the image via dropping the STF icon onto the HistogramTransform process.
For small scale features reduce the number of layers and for large scale increase the number of layers. To reduce the impact on the darker areas you can use the built-in Luminance mask or you can make your own.
It can take a bit of trial and error to get the best combination of stretch and HDRMT settings. I often stretch more than I normally would do, in preparation for HDRMT.
Clear Skies
Mick
« Reply #5 on: 2016 August 01 08:16:08 »
Thank you Mick. I didn't know about that feature. It works really well. Please see attached.
Offline Cosmick
« Reply #6 on: 2016 August 02 05:39:37 »
No worries  :)
Also works well on galaxies with bright cores. I often also add together the HDRMT processed image and the one with only a stretch applied. This allows fine control over the amount of HDRMT by varying the percentages - 50/50, 67/33, 25/75 etc.
Clear Skies
Mick
« Reply #7 on: 2016 August 02 09:59:44 »
Thanks Mick. Good idea. Do you also do that % add in PI? If so, what feature? Normally I would use a PS luminance layer for that for real-time % opacity preview.
« Reply #8 on: 2016 August 02 10:23:10 »
you can either use pixelmath to blend 2 images (Image1*0.5 + Image2*0.5) for instance, or create a mask (for instance, 50% = "0.5" in pixelmath expression, "create new image" ticked, and apply to image, then use the resultant image as a mask). then with the mask applied to Image1, apply the pixelmath expression "Image2" to Image1.
or, you might use an image derived from the main image as the mask (for instance, a luminance image which has been smoothed out slightly) when applying Image2 to Image1. or you might first multiply that smoothed luminance by some amount before using it as a mask. masking is computed in 'real time' so if you make changes to the mask image those changes will be reflected the next time you do an operation to the masked image.
« Reply #9 on: 2016 August 02 22:14:54 »
Thanks Rob. I think I need to gain a bit more experience in PI to do that quickly and efficiently.
