Author Topic: Error installing the new ImageRegistration module  (Read 4294 times)
Offline peresanz
« on: 2009 January 08 01:32:52 »
Hello,
 I downloaded the new  ImageRegistration module for Windows 32 and extracted the .dll file tot he bin folder as explained in the instructions. After running PixInsight I got the following error:
Unsupported API version:111:Module load error
I tried to install the module manually  (Process->Modules->Install Modules->Search and Install) and got the same error.
Pere
« Reply #1 on: 2009 January 08 02:59:20 »
Hi Pere,
Which version of PixInsight are you using? The new ImageRegistration module requires PixInsight Core 1.4.
Let me know if this fixes the problem.
Offline peresanz
« Reply #2 on: 2009 January 08 03:14:01 »
Hi Juan,
 I'm using the 1.4 version: Under the Help menu, About PixInsight shows: version 01.04.00.0457 eng (x86)
Note that this is the first tine that I install this module. I never installed any previous version. Don't know if this is of relevance...
Pere
« Reply #3 on: 2009 January 08 04:05:02 »
Hi Pere,
Please install version 1.4.1.460. Then install the IR module manually, as you did before, and it should work without problems.
Sorry for the inconveniences.
Cheers!
Offline peresanz
« Reply #4 on: 2009 January 08 04:20:32 »
Hi Juan,
 It worked. Many thanks for helping!
Pere
