Author Topic: Rejection issue  (Read 3945 times)
Offline Andrei Ioda
Rejection issue
« on: 2016 June 15 00:21:16 »
I have issue with rejection of satellite tracks. I tried any settings (Rejection algorithm, Normalization, Sigma high and etc.) in the ImageIntergration but didn't get result. I use PixInsight Core 01.08.04.1195 Ripley (x64) on OSX 10.11.5.
You can see the result on the attached screenshot and can download my original images for integration from here.
Re: Rejection issue
« Reply #1 on: 2016 June 15 10:17:24 »
You'll have to further reduce the sigma high parameter to reject the trails.
Offline RickS
Re: Rejection issue
« Reply #2 on: 2016 June 15 16:55:08 »
I have found, especially with small stacks, that rejection settings strong enough to clean up satellite trails can result in rejection of good data in the rest of the image.  My solution is to zap the satellite trails in the individual subs using PixelMath by drawing a white (value 1.0) line over the trail.  These lines reject very easily with weaker rejection settings.  It's not fun to do but I find it worth the effort.
Rick.
Offline Andrei Ioda
Re: Rejection issue
« Reply #3 on: 2016 June 15 23:25:37 »
Rick.
Thanks Rick. I will try.
Offline RickS
Re: Rejection issue
« Reply #4 on: 2016 June 16 01:46:08 »
Good luck, Andrei.  I use a PixelMath expression "iif(d2seg(x1,y1,x2,y2)<r,1,$T)" and define the symbols x1,y1 and x2,y2 as the endpoints of the satellite trail and r as the thickness of the line.
Rick.
Re: Rejection issue
« Reply #5 on: 2016 June 16 04:54:48 »
Rick
Thanks for sharing and explaining. I had never thought of that type of method for repairing an integration. Now I have some old images to work on. ;)
Andrei  You are going to like the results.
« Last Edit: 2016 June 16 05:17:05 by msmythers »
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: Rejection issue
« Reply #6 on: 2016 June 16 07:12:26 »
Rick,
Mind if I include that in my next version of my workbook?  Great solution.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline RickS
Re: Rejection issue
« Reply #7 on: 2016 June 16 13:50:53 »
Please do include it, Jim!
Offline Andrei Ioda
Re: Rejection issue
« Reply #8 on: 2016 June 16 23:20:06 »
Rick, Mike.
Thanks. I tried this method and it works. As the result of my work of M63 - http://www.astrobin.com/252475/C/
Re: Rejection issue
« Reply #9 on: 2016 June 16 23:28:25 »
Andrei
The image turned out great. Well worth the extra effort to remove the tracks.
Offline Andrei Ioda
Re: Rejection issue
« Reply #10 on: 2016 June 16 23:31:04 »
Andrei
Yes. Thanks Rick.
