i think the emphasis on ABE/DBE is only because most people have LP gradients and trying to neutralize the background while the background is polluted with LP would result in an incorrect neutralization result. same with the next step, colorcalibration.
while it's a pain in the butt, what you could do is break out the 3 color channels, then linear fit the red and blue to the green channel, and then put the channels back together and do DBE. or just do DBE to the split channels and then recombine them after DBE. that way you shouldn't have any problem seeing what you are doing. you will probably have to do another DBE after recombination as when looking at the mono files it's hard to detect the more subtle gradients.
