Author Topic: ImageIntegration noise estimates  (Read 3074 times)
Offline Geoff
« on: 2016 January 17 21:11:44 »
Attached is a small crop of an .xisf file, compressed to 7z.  If the file is cloned twice and then the three files are integrated using ImageIntegration (with its default values), then we would expect the median noise reduction to be 1.0000.  Instead, the process console reports a median noise reduction of 1.2225, which cannot be correct.
Geoff
Don't panic! (Douglas Adams)
Re: ImageIntegration noise estimates
« Reply #1 on: 2016 January 17 21:43:01 »
Geoff
I opened the FITSHeader tool and remove Noise00. I guess ImageIntegration is using that value for noise calculations.
Offline Geoff
« Reply #2 on: 2016 January 17 23:18:24 »
Geoff
Thanks Mike.  I realise that's what it's doing but it shouldn't.  My point is that if three identical images give a spurious result, how can we be sure of what is happening in other cases?
What seems to be happening here is that it estimates the noise in the image(x), takes the value reported by Noise00(y) and then computes y/x, which is reported as the improvement factor.
Geoff
« Reply #3 on: 2016 January 18 05:25:29 »
Geoff
I don't know if ImageIntegration is calculating a new noise estimate or it is really just passing the original noise estimate(Noise00) through since all three images are identical. That is a Juan question I would think.
« Reply #4 on: 2016 January 19 02:27:38 »
From the information your are providing, it seems there is no bug here, just the normal behavior. ImageIntegration uses existing noise estimates in input files by default. Estimates of the standard deviation of the noise are normally stored as NOISEXX FITS keywords (where XX is a zero-padded integer representing a zero-based image component index). These estimates are being generated by different tools and scripts, such as ImageCalibration, Debayer and SubframeSelector, among others. The idea is that noise estimates should be computed from calibrated raw, uninterpolated data (i.e., before image registration). This behavior can be disabled by checking the ignore noise keywords option of ImageIntegration, which forces recalculation of noise estimates (however, you should clear ImageIntegration's cache first to make sure that existing estimates are not being retrieved from the cache).
If the NOISEXX estimates were computed from uninterpolated data, but the image that you are using has later been interpolated (for example, because it has been registered), then the NOISEXX values no longer correspond to the current pixel data of the image. ImageIntegration, ImageCalibration, Debayer and SubframeSelector compute noise estimates using an algorithm based on the multiresolution support (MRS), so another possibility is that the existing NOISEXX values have been calculated using a different algorithm, which may give slightly different values. In both cases, getting a final effective noise reduction (ENR) value that is not exactly 1.0 is normal in this case.
ImageIntegration evaluates the standard deviation of the noise in the integrated result image using MRS, then this noise estimate is compared to estimates acquired from the input data set (either NOISEXX keywords, newly computed estimates, or estimates retrieved from the cache). If different algorithms are used for noise evaluation, or if the original noise evaluation was done before interpolation, in general the resulting quotients won't be one, even if three or more duplicates of the same image are being integrated.
Anyway, these differences have no practical consequence. It can't be stressed enough that effective noise reduction estimates are not absolute values (see the documentation for ImageIntegration). Your goal is to maximize ENR with the appropriate rejection of outlier pixels for a given data set. The particular ENR values being used are immaterial, as far as correct implementations of valid methods are being used during the whole process, starting from the raw data.
