Author Topic: BPP script using previously manually made Master Darks and Bias Frames  (Read 2759 times)
Offline cdavid
    • Through Space and Time
Hi, I have always used BPP with my DSLR images and simply used Master Darks and a superbias from my library.
I have just acquired a QSI 683 camera.  I had created some master Darks, and a Super bias for my library.
Today when I went to use BPP with some subs of M33 that I shot last night I am getting an error stating that it cannot find a Master Dark of time 300s....
The master Dark is in the correct panel and I have master checked.  It also warned me about the master dark not matching the Flat frames.  I have never worried about shooting darks for flats....simply relying on my Master Bias.
Does anyone have any ideas what might be causing this?
CArlos
Hi Carlos, only a guess
by chance are you using a cosmetic correction instance on BPP? May be that instance refer to an old Master Dark.
Saludos, Alejandro.
Offline cdavid
Thanks Alejandro, actually no I am not.
I do not understand why this is happening.  With my old DSLR this was never an issue.  With then QSI camera which captures images through the SKY X, I am encountering this.....I wonder if it has something to do with the FITS header.
Offline themongoose85
My manually created master dark has the exposure time in the filename and I don't get this error.
Master_Dark_300sec_-20C.fit
Offline cdavid
Thank you....I will try that.  I see from the FITS Header that there is no exposure time associated with the master.  I guess it gets stripped off.
Thanks again
Carlos
