Hi Juan,
Thanks for the update, I applied it but unfortunately the issue did not go away
![frown :(](http://pixinsight.com/forum/Smileys/default/frown.gif)
It does seem to be related to disk access, when either the "Open" or "Load Project" dialog is brought up the application crashes, the dialog does pop-up but doesn't show any files, it shows "Working on it..." instead.
I have attached a screen shoot, not much there unfortunately. If you don't mine compiling with debug symbols I could run it and send you the call stack.
Though not universal, it does seem to be affecting Dell computers only, could it be coincidence? maybe but it seems unlikely, it could be something affecting only newer models, or the latest drivers. It would be interesting to see what those reporting the issue have in common.
-Carlos
