Author Topic: Ring around Stars  (Read 4313 times)
Offline bjgiii
Ring around Stars
« on: 2015 March 01 17:32:55 »
I've got these weird rings around my stars. Does anyone know what causes this and how to reduce/fix it? Thanks
Re: Ring around Stars
« Reply #1 on: 2015 March 02 06:57:34 »
Could you provide your workflow? There are many possible culprits, specially deconvolution.
Offline Harry page
« Reply #2 on: 2015 March 02 09:31:53 »
What scope are you using
Harry
Harry Page
Offline bjgiii
« Reply #3 on: 2015 March 02 14:06:51 »
This was stacked with pixinsight. The only thing done to the image was ABE and DBE. The image looks like this after just a STF. This was shot with a full spectrum Canon T3i, ccd cls filter and a WO STAR71. Could this be caused from the LP filter or a improper stack? Its been awhile since I worked on this image. I believe it was 60 lights, ISO 800@ 120s each. Also darks and bias, but I don't recall how many I used in the stack.
Offline Harry page
« Reply #4 on: 2015 March 02 14:28:35 »
Looks like a scope problem to me , what does a single sub look like
Harry
Harry Page
Offline bjgiii
« Reply #5 on: 2015 March 02 14:40:13 »
Here's one zoomed in.
Offline topboxman
    • Peter's Gallery
« Reply #6 on: 2015 March 02 14:52:23 »
Looks like out of focused stars. I don't think I've seen out of focused donuts shaped stars from refractors before. Out of focused stars from SCT usually results in donuts shaped stars.
Peter
Offline Harry page
« Reply #7 on: 2015 March 02 15:15:21 »
Yes very out of focus , then the stacking gives emphasis  the problem
harry
Harry Page
Offline bjgiii
« Reply #8 on: 2015 March 03 03:28:10 »
Thanks everyone. Another lesson learned.
Bobby
Offline TobiasLindemann
    • Trackingstation
« Reply #9 on: 2015 March 03 10:41:47 »
Hi Bobby,
the first picture looks to me like, some of the images are out of focus and others are sharp. Maybe you have a focusdrift, caused by cooling down or other reason. I think you should check all images in your series. Maybe there are some sharp ones, you can use.
Tobias
« Reply #10 on: 2015 March 03 12:00:23 »
You may use the SubFrameSelector script to reject the blured images, or inspect them with the Blink tool.
