PixInsight Version: 1.08.03.1123
MacOS: 10.10.1
Running on a 2013 MacBook Pro 13"
Installing:
The previous major installer was a single file that I simply dragged into the Application folder, updates and everything worked fine but the latest installer is a compressed file with the entire folder structure. Extracting work and the program runs and it tells me there are 14 updates, they download but will not install, instead giving me a unable to install updates. Can't find required Component(s) error message.
Select All
Now, I am a windows convert, Command A selects all or Click first, hold shift, click the last will NOT work at all if your list is icons or thumbnails. It only works if you are in list view. I confirmed it works in finder, so the issue is within PI. I am using the script BatchPreProcessing but it also happens in the PI Browser.
Maximize
When Maximizing the window it doesn't remain maximized, at random times PI drops behind the dock and I have to click the title bar again.
All of these could be me, the user, as I am relatively new to mac but Everything works fine on the older version that is loaded on my Mac Mini running the same OSx version. I have not updated it yet! Its PI version is 1.08.01.1092.
Jeff
