Author Topic: How to combine DSLR and CCD images  (Read 2558 times)
Offline Torsinadoc
« on: 2014 September 23 08:12:55 »
How do you combine CCD with DSLR
I would like to use the Ha or Lum (QSI 583) and color data from previous images DSLR (T3i).  Not really sure of the workflow.  Suggestions on combining (when and how)?
Offline sreilly
Re: How to combine DSLR and CCD images
« Reply #1 on: 2014 September 23 08:36:14 »
My suggestion would be to process each separately, save, and then do a Dynamic Align of the two finished images saving both as noted being aligned. At that point you can combine them using the LRGBCombination process by opening both aligned images, leave only the L box and choose that image. Drag the triangle over to the RGB image and save the resulting image. Note there will be a need to crop the image as I'm sure the dSLR image will be quite larger so the luminance data will only cover parts of the rgb data.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
