Author Topic: Can't see cluster in non-linear saved jpeg or tif image  (Read 2177 times)
Offline CharlesW
I imaged M71 briefly. Processed it a little in 32 bit floating and then did a Histogram Transformation so it's non-linear. When I save it as a jpeg or tif the cluster disappears and I'm left with an image showing very few stars. Would anyone mind telling me what I'm missed? I should mention that I reopened them in Gimp and Irfanview to see the results of the save as.
Re: Can't see cluster in non-linear saved jpeg or tif image
« Reply #1 on: 2014 July 22 15:07:43 »
Hi Charles,
The most probable cause is that you apply HistogramTransformation when a STF was applied (may be not a Auto STF).
Then be sure at the moment you save the image that the green line is not visible.
Saludos, Alejandro.
