Author Topic: Overscan - STX16803  (Read 2330 times)
Offline pvelez
Overscan - STX16803
« on: 2014 June 01 22:20:24 »
Hello gurus
I am just looking at overscan to see if that helps with my readout artifacts.
Would anyone have the overscan settings for a STX16803?
I see there are a few posts featuring the FLI camera for the same chip but I suspect that the SBIG camera is set up differently.
The spec sheet for the KAF16803 chip at
http://www.ccd.com/pdf/ccd_16m.pdf
has helpful info but I am struggling to work out precisely how many extra rows/columns to include when taking my calibration frames and to set up the overscan settings in BPP
Much obliged for any assistance
Pete
Offline bitli
Re: Overscan - STX16803
« Reply #1 on: 2014 June 01 23:58:45 »
Sorry, I do not have a specific answer but just some hint on where to look.
From the spec
Surrounding the periphery of the device is a border of light shielded pixels creating a dark region.
Within this dark region, exist light shielded pixels that include 20 leading dark pixels on every line.
There are also 20 full dark lines at the start and 9 full dark lines at the end of every frame.
Under normal circumstances, these pixels do not respond to light and may be used as a dark reference
This 'overscan' may be ignored or used by the camera hardware or driver (some camera do their own 'dark compensation' which then conflicts with our preprocessing, this is mostly entry level or consumer oriented devices). It may or may not be saved with the image.  If the image you get is 4096x4096, then the prescan area is cropped by the camera (this is usually the case by default) and you cannot use it in PI.  You may be able to find a way to persuade the driver or your acquisition program to save the prescan area, but not all camera/drivers supports this.  I am afraid that you will have to check with SBig or on their forum, as this is independent of PI.
You can check if your are successful by looking at a flat, it must be larger than 4096x4096 (see the spec for exact size) and must have a black border. Otherwise there is no overscan in the image and nothing you can do in PixInsight.
Please report if you have any success to find the overscan, i would like to add some information on the subject to the ImageCalibration documentation.
-- bitli
