Author Topic: Narrowband Scripts  (Read 3722 times)
Offline Warhen
    • Billions and Billions
Narrowband Scripts
« on: 2014 February 06 11:23:27 »
Juan et al, Congrats on the release of version 1.08.01, I've installed it today without incident and all seems stable! If you've recovered enough, :>) I'd like to get some comment regarding the state of Narrowband combination scripts. You and I had emailed privately about your fixing up the MultichannelSynthesis AIP scripts once 1.8.1 was stable which were in need of cosmetic and functional fixes. I also see the 'iconized' and I assume new version of the NBRGB script? I'm wondering if this script and the MS scripts might not be married and polished together to form a one-stop NB platform. Obviously, the goals would be to:
-Combine 3-channel NB images together
-Combine contributions of up to 3-channels of NB images with an RGB image, or Luminance+RGB one
It would seem that allowing NBRGB to function with or without an RGB component, would eliminate the need for the HaRVB, LRVB, and SHO scripts.
Thanks Mighty Juan!
Best always, Warren
Warren A. Keller
www.ip4ap.com
