Author Topic: PI boot errors  (Read 3206 times)
Offline Jules
PI boot errors
« on: 2013 February 04 16:56:57 »
Hi I have just got home and have been updating PI 1.8 with all the previous updates on my IMac running 10.8.2 . Now when I boot PI I see the following error messages.
Applications/PixInsight.app/Contents/MacOS/CloneStamp-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/CloneStamp-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/Debayer-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/Debayer-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/ImageCalibration-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/ImageCalibration-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/ImageRegistration-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/ImageRegistration-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/MaskGeneration-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/MaskGeneration-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/MultiscaleProcessing-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/MultiscaleProcessing-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/NoiseReduction-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/NoiseReduction-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
/Applications/PixInsight.app/Contents/MacOS/PixelMath-pxm.dylib
<* failed *>
*** PixInsight API Error: Module: /Applications/PixInsight.app/Contents/MacOS/PixelMath-pxm.dylib: Unsupported API version 138 (expected = 137).: Module load error
* Scripting resources updated.
34 of 42 module(s) installed.
The weird thing I have recently updated my MacBook pro and it was fine?
Re: PI boot errors
« Reply #1 on: 2013 February 04 23:54:20 »
You are probably starting an old version (RC2?) of PI.
Offline Jules
Re: PI boot errors
« Reply #2 on: 2013 February 05 03:26:32 »
Hi Georg
Thanks for the reply. I am still seeing errors like this from Batch process?
run --execute-mode=auto "/Applications/PixInsight.app/Contents/src/scripts/BatchPreprocessing/BatchPreprocessing.js"
Processing script file: /Applications/PixInsight.app/Contents/src/scripts/BatchPreprocessing/BatchPreprocessing.js
*** Error [001]: /Applications/PixInsight.app/Contents/src/scripts/BatchPreprocessing/BatchPreprocessing-engine.js, line 222: ReferenceError: Debayer is not defined
It talks about debayer, I have loaded a Lum image or is that a red herring?
Regards
Julian
Re: PI boot errors
« Reply #3 on: 2013 February 05 04:00:22 »
If you have messages like "Module load error
/Applications/PixInsight.app/Contents/MacOS/Debayer-pxm.dylib" then the Debayer process is not defined, and as a consequence BatchProcessing will fail.
I think it would be useful if you delete all PI installations from your system, and then do a clean re-install of 1.8RC3. It appears you have some dangerous mix of versions, and it is no wonder that this causes all kinds of errors.
Offline Jules
Re: PI boot errors
« Reply #4 on: 2013 February 05 04:27:15 »
Thanks Georg
I will re-install.
Regards
Julian
