Author Topic: Internet connection needed for PI  (Read 3078 times)
Offline dzso.bacsi
« on: 2012 October 26 05:32:40 »
Hi everybody!
After extensive research I decided not to learn dozens of AstroPhoto tools, but only one, the best. So I took a deep breath and bought PI. I downloaded and installed PI with my commercial license without any problem. However, every time I start the program it needs Internet connection to:
vps4175.inmotionhosting.com(173.205.125.124)
If I do not allow it to connect, I get this error message:
Unable to download repository information http://update.pixinsight.com: Network error: couldn't connect to host
The PI site says that with a license I do not need Internet connection to run. Question is: what do I do or did wrong and/or does it influence the normal program processes in any way if there is no Internet connection when I start PI without the so-called "repository information"?
Thank you in advance!
dzso.bacsi
P.S. Having a DSLR, I am afraid this is only the first questions in a long row of future ones... ;)
« Last Edit: 2012 October 26 06:20:21 by dzso.bacsi »
Re: Internet connection needed for PI
« Reply #1 on: 2012 October 26 07:04:55 »
Regarding DLSR, see http://pixinsight.com/forum/index.php?topic=4794.msg33149#msg33149 as a starting point.
Regarding Internet-Connection: The commercial (bought) version does not check the license via Internet. However, it checks for updates. If you dont have an internet connection, just click cancel and work without updates.
Offline dzso.bacsi
« Reply #2 on: 2012 October 26 07:34:16 »
Thank you Georg!
