Author Topic: How to stack images of Saturn?  (Read 12402 times)
Re: How to stack images of Saturn?
« Reply #15 on: 2012 June 07 11:36:58 »
Yes, center of gravity is the centroid.
By the way, this algorithm assumes that images are very similar (in contents and brightness). So, it is not designed to register images of an eclipse at several stages, a transit, or other variable phenomena. The reason is that the main function that we are optimizing is the mean quadratic error between the images. There are other functionals that work much better with highly different images, like those you may find in medical imaging, for example (in MRI, depending on the sequence and parameters, you may end with two very different images, of the same field).
Offline gvanhau
« Reply #16 on: 2012 June 11 08:52:21 »
Hello
Could it be possible to enter manual referece points to the standard alignment tool? I mean not necesarily stars.
I recenctly wanted to make a mosaic of the moon, and even if align_tool found some "stars", the final result was not very acurate.
Regards
Geert
Geert Vanhauwaert
« Reply #17 on: 2012 June 11 10:42:09 »
I think it would be useful if DynamicAlignment had a broader concept of "equaivalent points". Currently it only recognized stars, or -if you are lucky- some other featue. I was not so lucky with the SolarMosaic I handled in http://pixinsight.com/forum/index.php?topic=4343.0, and I guess Saturn also has few star-like features.
