Author Topic: First use of Pixinsight by Pixinsight beginner  (Read 3445 times)
Offline pgiraud
  • For understand the Univers
    • Mon astronomie
« on: 2012 May 08 03:27:21 »
I'm new user in France.
The Pixinsight, just downloaded has version # 01.07.04.759
As beginner i've some problems.
For exemple Pixinsight, at start, offers me 18 updates. I accept and updates are downloaded.
Exit Pix gives these 18 updates installed but with the result : " the update process has failed " and an empty Log file,
Then the check of updates installed gives :
What happens.
Many thanks for contributions and regards
Paul Theo
Paul Theo
Atlas EQ-G, dual mount APO 127 ED + SW 80 ED, Audine KAF 401 self made, PL1-M camera (QHY5), Atik 383L+ - M & filter wheel Atik EFW2, Nikon D70, Canon Eos 50D, Toucam Pro II modified B&W, PC Toshiba Satellite X200
Re: First use of Pixinsight by Pixinsight beginner
« Reply #1 on: 2012 May 08 04:24:43 »
Paul,
which OS are you using (apparently some version of Windows) ? Into which location did you install PI? Did you change anything regarding permissions or UserAccessControl (UAC) in Windows?
Offline Andres.Pozo
Offline pgiraud
    • Mon astronomie
« Reply #3 on: 2012 May 08 09:45:37 »
Thanks Georg and Andres.
My PC works with XP SP3 Home Edition (Intel Corel Quad CPU 2.5 Ghz).
PI is normaly located in Program Files folder on the C: hard disk.
Access permissions are allowed by BitDefender Total Security 2011 allowing PI.
Regards
Paul Theo
« Reply #4 on: 2012 May 08 10:28:36 »
So the link provided by Andres applies...
