www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Preprocessing script
« previous
next »
Print
Pages: [
1
Author
Topic: Preprocessing script (Read 3863 times)
JGMoreau
PixInsight Addict
on:
2012 March 30 09:22:33 »
After installing the latest preprocessing script, it appears that i get a still bayer image
after integration
http://www3.cablevision.qc.ca/astro/batch_preprocessing.jpg
I am a little shy declaring this a bug as there is a high probability i am
doing something wrong
Previous version of the script was ok.
If somebody can help it would be appreciated.
Camera is ST2000XCM osc.
JG Moreau
Logged
georg.viehoever
PTeam Member
PixInsight Jedi Master
Re: Preprocessing script
Reply #1 on:
2012 March 30 13:25:44 »
Did you check the CFA option?
Logged
JGMoreau
PixInsight Addict
Reply #2 on:
2012 March 30 13:46:12 »
Quote from: georg.viehoever on 2012 March 30 13:25:44
Yes, same thing with just the debayer module...
Win 7, 64bits
Logged
Nocturnal
PixInsight Jedi Council Member
Reply #3 on:
2012 March 30 14:03:09 »
Then you're not using the right RGB pattern probably.
Logged
JGMoreau
PixInsight Addict
Reply #4 on:
2012 March 30 16:48:42 »
Hello Sander, here is the result of older script at left and newer one at right, same image, same settings.
Something seems wrong, maybe its me
http://www3.cablevision.qc.ca/astro/calibration_integration.jpg
Anybody else have same problem ?
Corrupted script file ? will try to reload...
J Guy
Logged
Nocturnal
Reply #5 on:
2012 March 30 16:56:11 »
I misunderstood the problem, I thought you said a plain debayer run without a script didn't work either. What you are presenting here indicates a problem in the script for sure. Possibly caused by recent changes to the debayer module.
Logged
PTeam Member
PixInsight Jedi Grand Master
Reply #6 on:
2012 March 30 23:55:53 »
Nobody has changed the Debayer module since the latest release (December 2011). Have you tried with the four CFA patterns in the Debayer tool?
It could be also a FITS orientation issue. Open FITS Preferences (Format Explorer, double click the FITS item) and make sure you have 'Upper left corner' selected as the coordinate origin. PI uses the professional convention (lower left corner) by default but most amateur image acquisition softwares do not.
Logged
JGMoreau
PixInsight Addict
Reply #7 on:
2012 March 31 11:30:33 »
Hi Juan, sorry to be a pest and/or an idiot
Here are thing i tried :
-all bayer patterns
-all debayer modes
-different raw images
-reset settings
-checked fit preference for upper left corner
Its the debayer module that behave strangly on my machine, Win 7, 64
see a single raw calibrated image with just debayer module action :
http://www3.cablevision.qc.ca/astro/Calibrated_debayer.jpg
Might pass for noise, but an integration of 72 such frames looks the same
Anything else i could try ?
Thanks for your patience,
JG Moreau
Quebec
Logged
JGMoreau
PixInsight Addict
Reply #8 on:
2012 April 01 12:55:48 »
Hi, i have uploaded some images and calibration masters on the file sharing site.
Can someone try to calibrate/stack them and help me find what i am doing wrong ?
Camera is ST2000XCM, with BGGR matrix.
Thanks for your help,
Jean Guy
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
