Author Topic: ImageCalibration .CR2 TargetFrames + Output Integer sample format = Balnk Image  (Read 4831 times)
Offline NKV
Hello Juan,
Take one more bug. Actually i found it in my CosmeticCorrection, but same problem in ImageCalibration:
Target Frames: Canon.CR2 images.
Output Sample format "16bit-integer" or "Same as target" .fit
Result: Absolutely blank image. See Log and Statistics.
Note:  Calibration is OK, if set Output Sample format to "32bit-float".
Best regards,
Nikolay.
Waiting for "there is no bug here".
 ;D
Offline NKV
 ;D
Maybe...  Actually, I found the bug 2 year ago. But Juan ignored the report, and I forgot about the bug... so I will push Juan again and again... until he did not say: "there is no bug here, because..."
Also, I think ImageCalibration (I have code for Version 1.1.1.0077 only) is not compatible with 64bit images, because all MasterFiles limited to FImage(32float).
I don't ignore bug reports---what's the point in doing that? :) It's simply that I overlooked your report for some reason (I didn't answered you, which supports this).
I can confirm the bug. I can see where's the problem in the code. I'll fix it ASAP, although it actually has no practical relevance. In addition, I'll remove the 'same as target', '8-bit' and '16-bit' options because they make no sense.
So Sander, stop waiting for "there is no bug here"!  >:D
That's true. For example, in line 1690 of ImageCalibrationInstance.cpp you can see these declarations:
   Image* bias = 0;
   Image* dark = 0, * optimizingDark = 0;
   Image* flat = 0;
So you're right, all calibration frames are loaded as 32-bit floating point images irrespective of the original data type. The same happens for all target frames. This isn't a bug, but a simple design pattern: Actually, working with 64-bit images makes no sense at all for a calibration routine. Supporting them would complicate the code (and would duplicate its binary size) without any justification, from both theoretical and practical considerations. All intermediate calculations are always performed in double precision, but this is a different thing.
Offline NKV
Juan, please show me how you will fix the problem. I must do same in CosmeticCorrection module.
Hmm, after a closer look at the code, I'm not so sure that I understand the problem. Do you see the same problem with unbayered images (e.g., CCD raw images) saved as 16-bit images with ImageCalibration, or does it happen only with DSLR CFA images?
Offline NKV
I see problem only with CR2 files. CR2 file converted to 16Int FITS is working fine. No matter convert to RAW Bayer Mono or to Color. Any type of FITS working fine. Problem there are only with CR2.
Also, if ImageCalibration output set to 32Int, calibrated image is not pure black, but is very-very dark. See Statistics PrintScreen.
Offline NKV
The CR2 file.
PS Thanks for fileshare. ;)
