Author Topic: Flats in a pure RGB image....  (Read 4285 times)
Offline Emanuele
« on: 2010 August 14 13:03:33 »
This is not about PI so I am posting here....
I had a very interesting read - Vincent Peris replies here in the forums - about shooting pure RGB and how it is much better than LRGB.
So I am wondering: how do you take flats in a pure RGB image? Usually Luminance is the only one affected and thus flats are taken with the Lum filter only.
But in a pure RGB image...... ?
Thank you,
E.
Re: Flats in a pure RGB image....
« Reply #1 on: 2010 August 14 13:18:31 »
No... flats should be taken on every filter you have. The filter position may affect the intensity distribution. I have seen that.
Offline Jack Harvey
« Reply #2 on: 2010 August 14 14:36:04 »
Agree.  We take 5 flats for each wide band (L,R,G,B) and any narrowband filters (Ha, OIII, SII) we use for an image
Jack Harvey, PTeam Member
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #3 on: 2010 August 16 03:11:36 »
Yes, flats must be taken for every filter you use. Even more, if you take the camera away from the telescope, flats will change when you put it again in the focal plane. OTOH, light distribution can be affected also if we change focus position.
Vicent.
Offline dhalliday
    • on Flickr
« Reply #4 on: 2010 August 23 17:32:35 »
But in a pinch I find (for mono RGB work) that I can often use ONE of the flats for all 3 filter sets...
Just saying...
 >:D
Dave
Dave Halliday
SSAG/EQ6
CGE Pro
SBIG ST2K,ST10XME
« Reply #5 on: 2010 August 23 23:14:44 »
Flats are not difficult to acquire, and so are well worth the effort.
I take flats for ANY change in the optical path - and I take fresh flats every time there is a change. It takes me about 10 minutes to grab 30 new flats.
