Author Topic: PI1.61 wont run on Fedora 11  (Read 5260 times)
« on: 2010 August 01 12:06:19 »
Juan,
Here is the error mesage that I got:
[georg@fedora11-x64-win7-2 ~]$ PixInsight.sh
/home/georg/PixInsight/bin/PixInsight: /lib64/libc.so.6: version `GLIBC_2.11' not found (required by /home/georg/PixInsight/bin/lib/libfreetype.so.6)
I guess you are compiling PI now on something newer than Fedora11...
Re: PI1.61 wont run on Fedora 11
« Reply #1 on: 2010 August 01 12:15:57 »
I find it interesting (ironic really) that people used to complain about dll-hell on Windows and I've actually had more trouble in that regard with Linux than Windows itself :)
You may be able to find the correct glibc somewhere and put it in the pcl64/bin directory?
« Reply #2 on: 2010 August 01 13:13:54 »
Hi Georg,
Try:
su -c 'yum update glibc*'
I'm building on Fedora 13.
Sander, I agree, there are more practical issues on Linux than on Windows regarding system libraries. That's why there is a bin/lib directory in the Linux version of PI. However I can't include glibc in bin/lib because that causes more problems than solutions. I still have to improve PI's Linux distribution. Another option would be 'freezing' my Linux development machines with an obsolete Linux version, but that isn't my style ;)
« Reply #3 on: 2010 August 01 22:11:31 »
BTW, I'm using Fedora 13, and Ubuntu Lucid Lynx (glibc 2.11 is not available for Karmic Koala and previous releases).
« Reply #4 on: 2010 August 03 01:59:13 »
Georg,
Any news about this issue? Did the yum update solved it?
« Reply #5 on: 2010 August 03 02:35:03 »
No news yet. For the immediate blind solver problem, I have found a different solution posted last night. So no pressure here anymore.
« Reply #6 on: 2010 August 12 10:09:46 »
Hi Georg,
Try:
No, unfortunately this does not help, see log below.
[georg@fedora11-x64-win7-2 ~]$ su -c 'yum update glibc*'
Passwort:
Geladene Plugins: refresh-packagekit
Einrichten des Aktualisierungsprozess
Keine Pakete für die Aktualisierung markiert
« Reply #7 on: 2010 August 12 10:34:08 »
Hi Georg,
Unfortunately, Fedora 11 no longer receives updates. Try removing libfreetype* from bin/lib. There may be other libraries that also require glibc 2.11 in bin/lib; in such case remove them too. PI itself should not have a direct dependency to glibc 2.11.
Let me know if this works. Another option would be putting glibc system libraries on bin/lib (for example from Fedora 12/13).
« Reply #8 on: 2010 August 12 15:12:17 »
I have chosen to upgrade to Fedora 13. This was quite easy using the PreUpgrade method http://fedoraproject.org/wiki/PreUpgrade . Took about 4 hours of download and install -largely unattended. Unfortunately, after this X11 would not start any more. Solution: Upgrade to latest version of VirtualBox, and install guest additions as described in http://forums.virtualbox.org/viewtopic.php?t=15679 .
Juan: For future releases, please tell us which platforms you recommend (meaning you are sure they will run there, and others might run as well).
« Reply #9 on: 2010 August 12 15:45:40 »
He'll say FreeBSB :D BTW, as I said earlier, PI won't run either on Ubuntu 9.10 or previous releases (outdated glibc). It needs 10.4.
