Author Topic: Explanation of colors in DBE sample viewer?  (Read 3467 times)
« on: 2010 July 10 14:16:16 »
there is no context help for the sample viewer area in DBE. I imagine that area isn't just there for fun but how to I interpret the colors? It seems red is bad but how bad?
Re: Explanation of colors in DBE sample viewer?
« Reply #1 on: 2010 July 10 16:04:28 »
The information coded in the sample viewer is on a per channel basis. This means, you'll have to split in your mind the three RGB channels :) Basically, for a grayscale image, 0 (black) means that this particular pixel will not be included as a valid source for background estimation. 1 (white), by the other hand, means that is a perfectly good sample. Intermediate values means partial inclusion on the calculation (the factor may be considered as a weight).
So, the same happens on RGB channels, but there is no correlation between different channels. A red pixel means that only the information on the red channel has been included. A yellow one, red and green pixel values.
« Reply #2 on: 2010 July 11 07:40:27 »
Ah, gotcha. Thanks Carlos. Juan: could you please add a tooltip for that area?
