Author Topic: Write Failure  (Read 3670 times)
Offline twade
Write Failure
« on: 2010 June 13 14:56:23 »
Juan,
I have the following directory structure in Windows XP:
W:\Images\Comet McNaught (2009_R1)\300mm
PixInsight 1.6 can read from any underlying sub-directories; unfortunately, it cannot write to the following directory:
W:\Images\Comet McNaught (2009_R1)\300mm\Test
I'm beginning to think, the parenthesis are tripping it up.  What are your thoughts?
Wade
Re: Write Failure
« Reply #1 on: 2010 June 14 00:29:13 »
Are you trying to write FITS files? I found that writing fits is not possible for certain file names such as light (3).fts, while light3.fts works.
Re: Write Failure
« Reply #2 on: 2010 June 14 05:17:49 »
Hi Wade,
Initially I didn't believe that '(' or ')' were valid, acceptable, characters for file or path names. So I would simply have agreed with Georg
However. checking at http://en.wikipedia.org/wiki/Filename I find no mention of '(' or ')' being restricted ???
Whilst Windoze may be more forgiving, perhaps PI is less so ::)
This may require Juan to specify whether there IS a problem, and WHAT that problem might be.
Re: Write Failure
« Reply #3 on: 2010 June 14 06:00:00 »
See http://pixinsight.com/forum/index.php?topic=1254.msg6377#msg6377 for Juan's response to my original problem with file names.
Offline twade
Re: Write Failure
« Reply #4 on: 2010 June 14 08:48:43 »
Georg,
Thanks for the link to an older discussion.  It appears I will need to rename my original directory.  :(
Wade
