Author Topic: Can't install PI 1.8.8 on my Ubuntu computer  (Read 532 times)
Offline MAbr
« on: 2019 November 20 09:55:10 »
I had the version 1.8.6 installed according to this procedure:
https://pixinsight.com/forum/index.php?topic=6336.0
Unfortunately, it doesn't work with Version 1.8.8 so I am not able to update it.
Has anyone encountered this before? Any ideas? Any help would be great.
Offline John_Gill
Re: Can't install PI 1.8.8 on my Ubuntu computer
« Reply #1 on: 2019 November 20 10:53:32 »
Perhaps uninstall your existing PixInsight and then install the latest version.
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline MAbr
« Reply #2 on: 2019 November 20 10:58:26 »
Does not matter. The thing is that the installer file is not properly recognised.
I also already tried to use the installer of the previous version but that didn't correctly install the new version.
Offline John_Gill
« Reply #3 on: 2019 November 20 11:04:40 »
mmmh, did the new version download correctly.  I think there is a checksum for the download.  Please check that that the download is 100% and then try the install.  If the install fails then there should be an entry in a log file, which is normally found under /var/log
John
Offline MAbr
Re: Can't install PI 1.8.8 on my Ubuntu computer - closed Thank you
« Reply #4 on: 2019 November 20 11:41:57 »
Thank you.
I didn't find that checksum but I downloaded the new version again. Now it is working. I already intalled the new version and everything seems to work fine.
Thanks for the help.
