Author Topic: xisf and 300dpi?  (Read 2764 times)
Offline HadesZ
xisf and 300dpi?
« on: 2017 September 06 15:11:15 »
just wondering if its possible to save as xisf but keep a higher dpi than 72? (which is what its currently forcing atm for me)
I have customers that was high resolution prints, and 72 dpi is not what is needed for large print sizes.
-Tyler
Re: xisf and 300dpi?
« Reply #1 on: 2017 September 06 15:39:28 »
Hi Tyler,
Are you sure that you are thinking things through clearly here? You are really not interested in DPI at any point through pre- and post-processing. You are only interested in DPI once you have your final image, and have selected from that image the area that you wish to see printed out.
Now, at that point - sure - your image may well be in XISF format, but is it XISF data that you will be sending to the printer? Almost certainly not. You will either be converting the image to another format - one that can be sent to an external print house for example - or you will be using PixInsight to render the image directly to your own print driver, assuming that you have in-house capabilities to generate the size and quality of prints required by your clients.
In either case the DPI need not be stored within the XISF file. It 'could' be defined during either of the two steps I have mentioned above, although it is probably more 'normal' to define a 'physical' print area (in 'x by y' mm or inches) and then examine the returned DPI of the image as it will be printed.
I always use a local 'warehouse store' to print my large-format images. They use photo [rpcesses to create the images on 36" x 24" (914mm x 614mm) board-stock, and this costs around the $10.00 mark. I couldn't even purchase the consumables for that price, far less maintain the printer in the 'tip-top' condition that commercial customers would expect.
And, when I take an image to them for print, I just take the 'final image' to them in un-compressed (or very slightly compressed) JPG format. Of course, I will have looked at the pixel count based on the size of that final image, and would not bother to seek their expeertise if the image to be printed did not have enough resolution to warrant such large-format printout. In other words, I would not waste my time and money to print out an image that was much less than 11,000 x 7,500 pixels. And, to me, that is a really big image to be trying to process in PixInsight - it would be a 3x3 mosaic from my 10MP CCD Imager, for which might have to wait several years to acquire the raw data. (Thankfully, I do not image for anyone, bar myself, and I don't have the patience - or remaining life expectancy - to wait that long for any project to reach completion).
However, maybe I'm missing the point you are trying to make - can you rephrase the question and we can perhaps rethink a solution?
Offline HadesZ
« Reply #2 on: 2017 September 06 16:18:50 »
I actually did misunderstand something with DPI, for some reason I thought from a previous experience of mine that DPI cannot be increased after it has been decreased.. but this is false, DPI is just a setting used by printers. Therefore I can easily change the DPI on my .jpg or .psd to 300+ prior to getting printed even though it may currently be set at 72
thank you for the thoughtful reply,
« Reply #3 on: 2017 September 07 05:21:45 »
To set the resolution of an image in PixInsight:
- Open the Resample tool.
- Click the Reset button (bottom right corner) in case you have used the tool before. Make sure width and height are set to 100%
- On the Resolution section, enter the desired horizontal and vertical resolution in dots per inch or per centimeter.
- Check the Force resolution option.
Apply the tool to the image(s) you want to set to the specified resolution. If you select your image in the drop-down list at the top of Resample (or check the track view option and select the image), you can see the resulting dimensions of the image in centimeters and inches as you change the resolution.
Note that the same can be done with the Crop and DynamicCrop tools. Of course, you can resample/crop your image and set the resolution at the same time, in a single operation. The XISF format can store (and stores by default) image resolution metadata.
